askaVWsalesGuy
Deactivated Account
VW has just updated the order guides with a new option: 9W7 Voice‐controlled Bluetooth w/ audio streaming and phonebook download.
More at 11
More at 11
Thanks for the update. It's about timeaskaVWsalesGuy said:VW has just updated the order guides with a new option: 9W7 Voice‐controlled Bluetooth w/ audio streaming and phonebook download.
More at 11
740GLE said:people who shelled out for the 9W3 could have had best of both worlds if they waited for this, but oh well.
I shelled out for the 9W3 module and have no regrets as I've had use of it for almost six months now. We don't know for sure yet if 9W7 will be backwards compatible given other changes such as the RNS-315 navigation downgrade. Does the RNS-315 use the same connector as the RNS-510? Is the 9W7 module connector the same? Hopefully but uncertain. The 2011 models are not due until August I believe and then how long after that before the 9W7 module is available as a service part? I might consider upgrading once that happens but by then I will have almost a year's worth use out of the 9W3 module.740GLE said:people who shelled out for the 9W3 could have had best of both worlds if they waited for this, but oh well.
Anyone know the cost?maloosheck said:9W7 module part number: 7P6 035 730 C
For a BT solution? VW is insane!!Thunderstruck said:Not available yet, but the local dealer said it looked like it was going to be $625.
VWoA called me today to followup on my recent purchase of my 2010 JSW TDI as part of their customer satisfaction survey. When they asked me if there was anything else that they can help me with, I mentioned how I was unsatisfied with the BT not working as the manual states it should. He said that it's been well documented due to a large number of the same complaint. No hesitation, he knew exactly what I was talking about. I asked him if there would be any solution soon. He said not at this time, but he would log my complaint in also.GetMore said:I'm very happy to see that they are finally going to have a "complete" solution. I was (along with everyone else) very disappointed to find that I did not have the Phone functions in my car, and was going to upgrade to the 9W3, but have found streaming audio to be very nice. I get more use out of the 9W2 than I would from the 9W3.
Of course I'd much rather see the cost around $200 for the upgrade, but maybe with time it will happen.
Ditto! I'd love to know as well.sportwagen rick said:Where'd you get the 9w7? And how much if you don't mind me asking?
Can I ask what car you retrofit the highline white pixel cluster into?Mr. Timewise said:I paid approximately $480 including shipping for the 9W7. I got it from a VW dealer who gives VW employee prices to forum members. List price is $625, IIRC. I also bought a highline instrument cluster at the same time...that is what you see in the pictures I took. Note the 0 miles on the odometer! The new cluster was not yet adapted to the car (immobilizer/key thingy) when the pictures were taken.
It is EXACTLY the same form and fit factor as the 9W2. Easiest install ever! Bluetooth antenna is built-in just as with the 9W2.
I felt like I was Scotty on the Enterprise: Snick! and the Velcro'd Styrofoam holder for the module is out from under the passenger seat. Then release the electrical connector and pop out 9W2 module from the Styrofoam (you need to be a bit careful so you don't break the Styrofoam). Then plug in the 9W7 (don't mix up the 9W2 and 9W7 - they really are identical) and fit it into Styrofoam holder. Then lay the Styrofoam back onto the carpet and the Velcro holds it in place! And finally link your phone.
If the "microphone" button on a MFSW is coded to just mute the Radio you need to re-code it to add PTT (Push-To-Talk). The radio will still mute, but now the voice control becomes active.
The coding in the 9W7 was already correct, apparently, because none was needed. I did take delivery from a US VW dealer. The module was sent to them by VW expecting it was for a US car.
Here's the VCDS scan of the 9W7:Address 77: Telephone (J412) Labels: NoneThe fault is because Ross-Tech's 10.3 beta software does not yet recognize the module. I assume the "UHVNA" means UHV North America.
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007667973792
Coding: 0A00000000010100
Shop #: WSC 00000 000 00000
ASAM Dataset: UHVNA A01007
ROD: N/A
No ASAM data for: "UHVNA" (VW36)
1 Fault Found:
13636352 - ROD - Unknown Error Code
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 41
Mileage: 7538 km
Date: 2008.14.12
Time: 18:50:43
The coding is a completely different format in the 9W2 that was replaced. Here's the 9W2 scan before it was removed from the car:Address 77: Telephone (J738) Labels: NoneEverything works fine, although I have not tried an iPhone or any streaming music source (rSAP or A2DP). But the voice control includes a "MUSIC" command to access a Bluetooth source...I'll borrow a source and give it a try.
Part No SW: 1K8 035 730 C HW: 1K8 035 730 C
Component: Telefon H08 6600
Revision: 00008000 Serial number: 20389520162475
Coding: 412100
Shop #: WSC 00066 000 00000
No fault code found.
Note that as of now, voice control for the RNS-510 navigation system does not function. The European RNS-510 software allows this, but the US software does not. We're all waiting for the next release of RNS-510 software (SW1100 ???) that might add this feature.
rSAP is a completely different beast and it is not implemented in ANY US available BT module. Reason is rSAP capable BT module is virtually a separate GSM cell phone that just borrows your cell phone identity. GSM technology is only used by AT&T and T-Mobile in US, so these rSAP BT modules are useless with Verizon and Sprint. On the other hand you get the ability to read text messages on MFA+, save phone battery and better reception as the module has external GSM antenna.Mr. Timewise said:Everything works fine, although I have not tried an iPhone or any streaming music source (rSAP or A2DP).
