philipwight
the boost guage is when i was on the dyno and the other is on the freeway.
http://my240sx.piczo.com/?g=40691142&cr=1
Put down the purse and cut that exhaust off in favor of something a little more manlyRover96 said:Something doesn't look right with those vids. Also, how do you get your car to sound like that?
LMFAO!!!vwmikel said:Put down the purse and cut that exhaust off in favor of something a little more manly
I like this one ... http://www.mcnallyelectronics.com/Index.htmljsrmonster said:sounds like a monster. Your mph seems 10mph lower than oem tx at 5500rpms. You running 195's or shorter FD? or, impulses set high in cluster? Get it to the track before it blows - hehe.
Jeff
btw I like this boost gage: http://www.autometer.com/cat_gaugedetail.aspx?gid=3152&sid=11
this one is extreme: http://www.autometer.com/cat_gaugedetail.aspx?gid=3477&sid=11
Nice!! sounds very strong.philipwight said:this is what i have. the top right display is for boost. you can use any sensor that you have the calibrations for. right now i have an AEM 5 bar map sensor installed just dont have it wired right now. AEM has anothere sensor that i could use that goes to 150psi. but i dont think i need that. the mechanical guage i was using is just hanging out in the cabin. just used it to get started.
philipwight said:the boost guage is when i was on the dyno and the other is on the freeway.
