I have a small leak coming from the bottom pivot pin.
(Image found online not my image)
Does any one know what is the O-ring size that I need? I just would like to make sure i have an O-ring that will work before doing the fix.
The O-ring size that I am looking for are the 4 small ones in the 02J gasket seal kit.
If I drain the transmission fluid and leave the transmission in neutral can I remove the pivot pin, install a new O-ring and reinstall it without any ill effect?
thank you
thank you
