Old February 8th, 2015, 14:23   #1
Cobrargc
TDI(s): 2013 Jetta
Exclamation Possible blown head gasket
So does anyone now what kind of uphill battle I'm going to be in with VW in regards to a blown head gasket due to intercooler icing? Hopefully its just a head gasket and not a cracked block.
http://i774.photobucket.com/albums/y...psa9283a2a.jpg
I've got 11K miles on my '13. An earlier thread mentions that I started my diesel after it had sat overnight in the garage following a long trip in cold weather. It turned over very slowly and at first I thought I might have left something on and ran the battery dead.
I checked the oil immediately after I was tipped off about the icing from another user on this forum. The oil looked fine after the initial start. Today I drove it for 5 miles to see if would run OK. It ran fine. I drove it long enough to get the engine up to temp and the cooling system under pressure. The photo shows what the dipstick looked like after the I allowed the engine to cool down.
Cobrargc is offline   Reply With Quote
Old February 9th, 2015, 12:33   #2
Tom W.
Tom W.'s Avatar
Fuel Economy: Getta 49MPG IDI 60MPG Passat 34mpg
Default no worries
I cannot imaging that you will have any issues w VW about this. You are waaaaaay within the warranty
Chemically cleaning your turbo: http://forums.tdiclub.com/showpost.p...8&postcount=48
canadiangrizzly's Diagnosing limp mode: http://forums.tdiclub.com/showthread.php?t=179589
GoFaster on loss of power:
http://forums.tdiclub.com/showthread.php?t=75959
Tom W. is offline   Reply With Quote
Old February 9th, 2015, 15:37   #3
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Some "milkshake" is not out of the ordinary on a dipstick on a lightly driven car. There are a couple of coolant passages close to oil galleries in your engine, but none that would likely be affected by water intrusion. More likely would be to bend a rod.
5 miles is also not enough to boil off condensed water like that.
Take the car for a long highway drive and then recheck the dipstick. You will find that the condensation has either gone (no issue) or that it has stayed (leaking HG).
My money is on it just being normal condensation.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old February 10th, 2015, 11:57   #4
Cobrargc
TDI(s): 2013 Jetta
VW just told me the engine is fine and there isn't any water in the crankcase. They also told me that the creamy stuff on the dipstick is condensation, but I am not buying that. My garage is 60 degrees. This is a typical summer time low when a vehicle is outside. It's not like I started it up at -5 degrees and took it for a short drive. The engine was at 60 degrees to start with and ran for 45 minutes.
They are going to install the intercooler upgrade on Wednesday.
There was no mention of them changing the oil. This is good because I plan to pull a sample and send it off for analysis. I also want to have a reputable third party check the cooling system for a leaks. If there's any substantial glycol found in the oil sample, I will get VOA involved.
I'm curious as to their explanation for the hard start. Do they believe it in fact was a deicing issue or are they just doing it because I threw down a printed copy of the "intercooler icing" thread I'd printed? I have a lot of questions to ask them when I pick the car up.
Old February 10th, 2015, 12:35   #5
Ol'Rattler
Ol'Rattler's Avatar
Sounds like you have your panties twisted.
Intercooler iceing has nothing to do with moisture in the oil. In winter, the 60 degree garage might setting you up for intercooler iceing. What happens is because the engine is above freezing and then you go out side were it is freezing, you get condensation from the warm moist air that is in your intake tract. Might explain the milky oil, as well.
Do you drive a lot of very short trips? Moisture in the oil may be be because of that. The slow start may have been related to intercooler iceing, so the TSB might fix that.
Unless they can duplicate it, don't expect them to understand the slow start issue. Wouldn't hurt to stop expecting to find a bad guy at your dealer and just work with them.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old February 10th, 2015, 12:41   #6
Vince Waldon
Vince Waldon's Avatar
Sorry OP but I gotta agree.
On the other hand, oil analysis looking specifically for coolant as opposed to simple water is a reasonable next step if you really want to dig in.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old February 10th, 2015, 13:24   #7
Cobrargc
TDI(s): 2013 Jetta
Yes I do kind of have my panties in a twist. I think most people would under the circumstances.
Is it safe to say the no start or no crank was due to the icing? If so, the water that entered the cylinders caused a hydrolock condition that prevented the engine from turning over correct? Where would this melted water have gone? The exhaust valves don't open until after TDC. A cranking engine does not have the ability to compress water.
I'm not as concerned with simple moisture in the oil. What concerns me is the forced engine start damaging the head gasket and allowing the coolant a direct path into the crankcase.
This vehicle is used only for vacations and trips out of town. I've never used it for trips to and from work or the store. The dealership said I have about 1000 miles on the September '14 oil change they did. Again, I checked the dipstick immediately following the hard start. It was clean. The contamination on the dipstick was after my first drive with it. I think the no start-hard start combined with the contamination on the dipstick was a major red flag for me.
Would anything other than an icing hydrolock condition have caused the engine not to turn over? I assume the dealership would have load tested the battery to see if it was good. The car does a fair amount of sitting and this isn't good for batteries.
Thanks for all the help. I appreciate it.
Old February 10th, 2015, 13:28   #8
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Why do you keep pointing to a head gasket??? That is probably not at all a possibility.
oilhammer
www.cardocautomotive.com
Old February 10th, 2015, 13:45   #9
LogicBomb
TDI(s): 2014 Passat
The oil itself looks fine, it looks like a little condensation mixed with some residual oil at the top of the stick? Nothing to be overly alarmed about IMO. Also, a head gasket would/should have affected the oil in the pan, which is clearly shown to be clean....
LogicBomb is offline   Reply With Quote
Old February 10th, 2015, 16:11   #10
ATR
ATR's Avatar
Yes! Definitely get the oil tested on the next oil change:
http://www.blackstone-labs.com/
In the meantime keep a close eye on the oil.
Drivers Wanted
-2011 Golf TDI 6MT = gone but not forgotten!
-2017 Golf GTI Sport 6MT
***Official maintenance schedule for your VW [PDFs inside]***
ATR is offline   Reply With Quote
Old February 10th, 2015, 17:33   #11
red16vdub
red16vdub's Avatar
I have to agree with this ^^^. My mk3 used to do this for the first 50k when it was new, Car still running today with 189k on the clock and the only change to motor was a reman starter.
Mk1 Gti /scIROCco 16v /A6 quattro sport / Mk4 TDI JSW 5spd
17/56 turbo, RC ASV-5+ @ 28psi, 3 Bar Map, 11mm IP, PD Lift Pump, R520's, McNally boost/egt, Euro FIS full screen Cluster, PD 150 Intake/racepipe, PD 150 plastic T.I.P + R32 maf air mods, Kerma 2.5" Fmic, Kerma 3"T-B exhaust/resonator/ Aero turbine muffler, SBC stage 3 Endurance, GLi brakes F/R , GLi axles, H&R Bilstein sports cup kit.
red16vdub is online now   Reply With Quote
Old February 10th, 2015, 17:34   #12
Windex
Windex's Avatar
These vehicles are not an optimal solution for short trips.
1000mi since September - if accurate, do yourself a favor - drive the car more, or trade it in for a camry - gas or hybrid.
Short trips create condensation in internal combustion vehicles - no two ways about it.
<-source - career car and heavy truck/diesel mechanic
As above, water ingestion does not force anything into the crankcase - that doesn't happen. Hard to believe you're not concerned with condensation in the oil when that's the picture you linked.
Has the coolant level gone down at all?
Old February 10th, 2015, 17:46   #13
Curious Chris
Fuel Economy: 47/42/38
I purposely never get a job too close to where I live. Right now it is pretty short at 17 miles but it is freeway miles and the engine is fully warm when I make the turn onto the south interstate which is the last 12 miles.
Yes 1000 miles since September buy a Leaf.
I am putting on about 12,000 miles a year and I am 268,500 miles
Curious Chris is offline   Reply With Quote
Old February 10th, 2015, 18:52   #14
ATR
ATR's Avatar
In case you missed it he did say that the car was only used for long trips...
Drivers Wanted
Old February 11th, 2015, 05:07   #15
Windex
Windex's Avatar
1000 miles since September? Wrong car for the application.
blown head gasket or other? rustytigwire TDI 101 11 June 5th, 2012 09:23
Help, I think I may have blown my head gasket vonbuj TDI 101 6 January 18th, 2012 09:13
Blown head gasket?? tdiology VW MKIV-A4 TDIs (VE and PD) 4 May 13th, 2011 15:59
What Does A Blown Head Gasket Look Like? jammcm17 VW MKIV-A4 TDIs (VE and PD) 7 July 15th, 2010 05:38
blown head gasket?? secretofnims VW MKIV-A4 TDIs (VE and PD) 9 June 17th, 2009 17:05
Page generated in 0.17890 seconds with 11 queries
[Output: 134.30 Kb. compressed to 112.67 Kb. by saving 21.63 Kb. (16.11%)]
