Old January 17th, 2012, 20:17   #1
vonbuj
TDI(s): 2006 Beetle
Default Help, I think I may have blown my head gasket
I drive a 2006 TDI Beetle and was driving home from work and heard a pop then the car had a whole lot less power, limp mode? Took car to VW stealership and they said that the air Intake Flap Motor was bad , was stuck in the closed position and this caused the crankcase pressure to rise and blow oil out of the oil filler cap. They said $750 would fix it I said no way and I took the car. Had a friend send me a used but good Intake Flap Motor , installed it but the same problem. Left the battery disconnected all night to see if the car would reset itself and get out of LIMP mode but nothing changed when I reconnected the battery in the morning, still very little power. Drove car home from friendís garage 40 miles on low power and the car used 1 qt low (no oil coming out of oil cap). Jacked up car to check actuator rod and it moves freely. Had friend rev car up and I watched the actuator rod to see if it moved and it didn't. Also noticed the hole back of engine was coated with oil. Engine sounds a lot louder then normal.
Any advice would be welcome as I drive the car for a living as a computer service tech and really need to get it back running right. Thanks for your help
vonbuj is offline   Reply With Quote
Old January 17th, 2012, 20:20   #2
1963gp
1963gp's Avatar
check the intercooler hoses.
1963gp is offline   Reply With Quote
Old January 17th, 2012, 20:48   #3
Seatman
Seatman's Avatar
Fuel Economy: No idea
+1 It's exactly what you're describing, check the hose from the turbo hasn't come off or burst. It goes from there to an intercooler which looks like a small radiator then it goes back up to the intake manifold. Just follow the big fat pipe.
Seatman is offline   Reply With Quote
Old January 17th, 2012, 20:54   #4
whitedog
Head gasket is WAAAAAAAAY down the list of failure, so put that one on the shelf.
Just for grins, you may want to pull the valve cover and take a look at things under there looking at the cam profiles and followers.
And look at the intake hoses from the turbo to the intake.
Old January 17th, 2012, 20:55   #5
fixumrich
The Periodontist
fixumrich's Avatar
TDI(s): 2001 bug
Fuel Economy: 59 high 48 with mods
The E-asv fail all the time on bew,s . did the upper ic hose blow off . headgasket . serious . dealer . whitedog is the doggie collar man . i run 38 psi at wot and never have just blown a gskt. your gotta get that thing real hot ! R
Fix Um Haus - 503.286.0903
7104 N. Lombard
Portland, Oregon
fixumrich is offline   Reply With Quote
Old January 17th, 2012, 21:17   #6
whitedog
I would hope it doesn't need a doggie collar. If it does and the dealer missed that, then... well, I'm sure anyone can miss something so obvious.
Old January 18th, 2012, 08:13   #7
Seatman
Seatman's Avatar
Just a thought but you best check your turbo hasn't split in two aswell, I have seen that on here and it can sound the same.
Blown head gasket?? tdiology VW MKIV-A4 TDIs (VE and PD) 4 May 13th, 2011 14:59
What Does A Blown Head Gasket Look Like? jammcm17 VW MKIV-A4 TDIs (VE and PD) 7 July 15th, 2010 04:38
blown head gasket?? secretofnims VW MKIV-A4 TDIs (VE and PD) 9 June 17th, 2009 16:05
Blown head gasket again buck toenges TDI 101 1 January 5th, 2009 09:58
blown head gasket pdxgrease TDI Power Enhancements 2 August 16th, 2005 12:23
Page generated in 0.12550 seconds with 11 queries
[Output: 80.24 Kb. compressed to 69.70 Kb. by saving 10.54 Kb. (13.14%)]
