Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old January 27th, 2004, 12:57   #1
Got50MPG
Default What is the best bank for buck eco mod?
I own a 96 TDI and on the way back from NYNY to KCMO I got just above 44mpg doin 80mph. My brother and I are 'big boned' and we had a whole bunch crap with us so I think that contributed to the sub 50mpg. Besides inflating the tires and removing the snow screen what would be the best bang for buck eco mods?
Thanx,
Got50MPGs
Got50MPG is offline   Reply With Quote
Old January 27th, 2004, 13:04   #2
DaveC
Slow down! How can your expect to get good fuel economy driving 80 MPH?
Do about 60 MPH, and you will get closer to 50 MPG.
DaveC is offline   Reply With Quote
Old January 27th, 2004, 13:46   #3
Got50MPG
I am used to driving performance cars so it'll take a while for me to lay of the go pedal.
Old January 27th, 2004, 19:16   #4
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
I interpret that last reply to imply that you don't really want economy tips.
OK, here's one that will still allow you to drive at that speed;
Don't use the brakes.
Any fuel used to accelerate and to generate momentum is squandered when it is turned into heat and brake dust. Once at speed, whatever it might be, you have turned fuel into momentum which is still useful to you. Braking and turning that momentum into heat and noise will not allow you further use of that energy.
I still drive a performance car, but I can get 90+ mpg in it when I concentrate on economy.
Old January 27th, 2004, 19:55   #5
tadc
Fuel Economy: 45/42/37
You can't get 50 MPG doing 80 MPH. In fact in my car I'm lucky to get 40 MPG at 80.
That said, slow down going uphill and speed up going down. Clean your snowscreen/airfilter, advance your timing, inflate your tires, throw out any unneeded weight, wash the car, use cetane-improving fuel additives, and I've read that single-digit percentages of biodiesel can return single-digit improvements in MPG due to improved lubricity.
tadc is offline   Reply With Quote
Old January 30th, 2004, 12:19   #6
Tarbe
[ QUOTE ]
[/ QUOTE ]
Both of these benefits are achieved by using Schaeffer's Soy Shield. It is 50% biodiesel (from soybean oil, of course!) and 50% various additives.
I have never heard of anyone using Soy Shield and not liking it (well, except for chiefdiesel!!!). I never leave home without 10oz in my truck just in case I get fuel while I'm out!
Tim
Tarbe is offline   Reply With Quote
Old January 30th, 2004, 13:51   #7
gardentender
RIP, Gone But Not Forgotten
Fuel Economy: 53+/46/41
i often attain 46-47MPG on 80 mph trips of 180 to 200 miles length.
gardentender is offline   Reply With Quote
Old January 30th, 2004, 15:32   #8
Rammstein
TDI(s): Golf 92 D
Fuel Economy: 4.31/5.05/6.16
Change your tranny oil for Redline MTL.
Redline's website
Rammstein is offline   Reply With Quote
Old January 31st, 2004, 09:02   #9
AkAl
TDI(s): 97 passat
yes Ramstein is correct I got 3 mpg after going to mtl smoother shifts also. [img]/images/graemlins/grin.gif[/img]
AkAl is offline   Reply With Quote
Old January 31st, 2004, 09:54   #10
Rammstein
TDI(s): Golf 92 D
What did I tell you guys?
3 mpg?
Wow, that's awesome! [img]/images/graemlins/grin.gif[/img]
Old February 1st, 2004, 09:47   #11
BioDiesel
TDI(s): '98 Jetta
How about fuel at $0.10/gallon?
Then you don't care what your mpg is.
BioDiesel is offline   Reply With Quote
Old February 1st, 2004, 15:31   #12
mackwood
Fuel Economy: 38/47
3mpg increase is alot. Can you use redline for newer A4 manual trannies? Is it better than the factory fill? If there is such an increase in mpg's alot of people must be using this stuff. Can anybody chime in if you are using Redline MTF on a A4 and give your results?
mackwood is offline   Reply With Quote
Old February 3rd, 2004, 16:15   #13
hatchy20TDi
hatchy20TDi's Avatar
Redline MTL is BUTTA! Used it for the first time in my Integra and WOW did the car feel different. Smooth shifts and I never had a problem finsing the gears. Be expected to pay about $10 a quart for this stuff, but it's well worth it.
hatchy20TDi is offline   Reply With Quote
Old February 3rd, 2004, 22:26   #14
tadc
[ QUOTE ]
[/ QUOTE ]Yes, and I'm one of the "lucky ones" that gets 10% less MPG for no apparent reason.
Old February 7th, 2004, 07:52   #15
03_01_TDI
Banned
TDI(s): Na
I've not used redline in my Jetta but I along with most BMW motorcycles riders use it for the trans and driveshaft. The BMW dealer sell it in the store. That should speak of how good Redline is.
I'll probably get around to putting it into the Jetta, soon.
03_01_TDI is offline   Reply With Quote
© 1996 - 2020, All Rights Reserved
Page generated in 0.15685 seconds with 10 queries
[Output: 113.49 Kb. compressed to 93.70 Kb. by saving 19.79 Kb. (17.44%)]
