Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW Touareg TDIs
VW Touareg TDIs This is a general discussion about Touareg TDIs. Non TDI related postings will be moved or removed.
Old June 3rd, 2020, 11:53   #1
TDI_Nate_
Default 2012 Treg TDI Rear Wiper washer issue
Hi all,
So recently my wife and I pulled the trigger on a buy back 12 Touareg TDI and so far we love it! Coming from owning and driving all 4 cylinder TDI's its a far cry, and her coming from a Cruze is a really far cry haha, but it's awesome. Anyway my issue, when you push the wiper stalk away to activate the rear washer nothing but bubbles come out the nozzles at the rear wiper stalk. It's full of washer fluid, I can hear the pump motor running, and the wiper does its thing. When the pump runs it changes pitch almost like it's pressurizing or something. Also after repeated attempts I find no leaks anywhere in or out of the vehicle. So what do you all think I should do? Is there a rear washer tank that I'm missing, I am new to treg life. Or something else? I think I figured out where the washer fluid bottle is for the front (in the pass. fender and it's a pain to get to..correct me if I'm wrong). Also is there a designation to the generations of Touareg like there are for the other VW models so I know in the future? Also if this isn't the best forum to be looking let me know and I'd love suggestions.
Thanks!
TDI_Nate_ is offline   Reply With Quote
Old June 3rd, 2020, 16:35   #2
redbarron55
The rear nozzle is bad about rusting internally and clogging. I have cleaned mine several times and it still clogs and is clogged now.
The nozzle pulls out fairly easily and a fine wire can be used to clear the hole, but the rust back in the wiper keeps on coming. Flush really well or you will be right back there soon.
redbarron55 is offline   Reply With Quote
Old June 4th, 2020, 11:15   #3
TDI_Nate_
Ok that makes sense! How does one take it apart to get to the nozzle pieces?
Old June 5th, 2020, 04:56   #4
redbarron55
Here is the thread I saw and used:
https://www.clubtouareg.com/threads/...uid-t3.145354/
Old June 22nd, 2020, 13:02   #5
TDI_Nate_
Thanks for all the help and suggestions, I used that link from the Touareg forum and fixed it this weekend! Now onto question two, is there a designation for the years of Touareg? Like I've seen maybe the 2012 and up is called the Touareg 2? I'm hoping it'll make looking for things easier if I know the specific designation. I suppose if there really isn't one then oh well I'll manage!
Old June 23rd, 2020, 11:02   #6
redbarron55
I think they are T3, but I have practice being wrong
2012 Jetta TDI Windshield Wiper Issue.... Cwilkers VW MKVI-A6 Jetta Sedan (~ 2011+) 16 March 8th, 2014 10:59
New 2011 JSW Owner, No Chirp on Lock, Dome Light Stays On, Rear Wiper/Washer Issue re2st VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 21 April 15th, 2011 10:48
Rear Wiper Washer axelseaa VW B5 Passat TDIs 10 April 10th, 2011 08:12
Rear window wiper/washer hrdwrk VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 25 March 3rd, 2011 13:10
Rear washer fluid spraying when front washer fluid and wiper activated rojhero VW MKIV-A4 TDIs (VE and PD) 4 January 12th, 2011 05:26
Page generated in 0.13167 seconds with 11 queries
[Output: 72.71 Kb. compressed to 63.93 Kb. by saving 8.78 Kb. (12.07%)]
