Old June 2nd, 2020, 15:13   #1
backfast61
Default Ignition key won't go into ignition
Need help. 2006 Jetta TDI
Any helpful advice. I'm stranded. Thanks
backfast61 is offline   Reply With Quote
Old June 2nd, 2020, 16:17   #2
kdawg89
Google it, very common issue. Canít remember off hand best way to fix it.
I think I used something skinny to work with it. The shutters get jammed if I remember correctly.
Edit read post 3 https://forums.tdiclub.com/showthread.php?t=207047
15 Golf TDI SEL DSG, Kerma TDI Tunes, Malone DSG Tune
Sold:06 Jetta, Darkside GTB1749V turbo, stage 4 malone tuning, 3 bar map, EGR delete, ASV deleted, buzzken catless downpipe, IDParts billet cam
kdawg89 is offline   Reply With Quote
Old June 2nd, 2020, 19:12   #3
backfast61
Default Got it 👍
Sprayed some special Lock lubricant in to the ignition lock and also inserted some tip cleaners and went in and out and freed up the tumblers.... Then I was able to insert my key... apparently alot of dust came out of the lock. Blessings. Hope this helps! Eddie
Key won't turn all the way in ignition relumalutan VW MKV-A5 Golf/Jettas 6 January 14th, 2020 13:23
Key Won't Go In Ignition Switch dieselonly VW MKV-A5 Golf/Jettas 37 October 3rd, 2018 04:49
Key won't turn in the ignition Roaddog TDI 101 3 December 15th, 2010 11:19
Key won't go in ignition! judisjetta TDI 101 4 February 25th, 2009 09:57
key won't go into ignition switch vector1 VW MKV-A5 Golf/Jettas 5 January 24th, 2009 13:28
© 1996 - 2020, All Rights Reserved
Page generated in 0.13722 seconds with 11 queries
[Output: 57.11 Kb. compressed to 51.92 Kb. by saving 5.19 Kb. (9.10%)]
