JrCheese
Hey there some help would be appreciated with this issue I’m having... first diesel I’ve ever owned and I’m just a young dude (21) with a basic knowledge of cars trying my best to start my vehicle is a 2004 Golf TDI 1.9 BEW (EGR deleted, and Malone stage 4 tune if that matters for this issue)
So I recently discovered the hard way that VW have very low oil pans... managed to gouge a pretty gnarly hole into mine on a nasty rock someone had put in the middle of the road. I’m not dumb I know to turn the vehicle off as soon as possible however I was on a uphill climb with no where to safely pull over so I continued to drive for another 60-100 seconds so I could get over this hill put it into neutral turn it off and coast to where I could park.... unfortunately for me the car turned off of its own accord just as I got over the ridge now the engine didn’t seize up cause it was still in gear and rolling (stopped that quick put it into neutral and coasted instead) parked saw the oil trail and got a tow back home. Spent the time getting the oil pan off...(and those two stupid bolts of you know what I’m talking about) replaces the old pan.... filled with oil started it up it ran fine and idled fine... let it sit for a hot minute idling (15-30 min) turned it off and replaced the oil again and the oil filter (in case of anything still in there ya know just trying to be safe) all looked golden...
took it off the jack stands got it on the road.... no boost at all... worst nightmare did I cook my turbo with no oil or??? Those were the thoughts going through my head.... got it back up on stands... took the intake side off the VNT-17 turbo off saw there was still oil coming out of the cold side and gently felt if it span freely (which it did) then I felt for any play.... which I couldn’t feel except the sliiiiightest amount which I’ve been told was normal (the play was from hot to cold side of the turbo not around and around) I wasn’t sure if my waste gate blew as well so I sucked on a vacuum hose leading to it and could hear it when idling change a little but nothing major.. tried moving the actuator cause I’ve heard they can go on this size turbo but it seemed fine also .... thought maybe the only thing left is if the hot side sheared leaving the cold side free which then I’d have to get some penetrative lube on the exhaust side and crack those bolts off to see if the hot side spins freely at all... otherwise I’m up ****s creek don’t know what to check next or how.... before anyone asks I didn’t hear any bad noises when the car turned itself off but that wasn’t from the lack of potential noises I just couldn’t hear it over my music while I was trying to navigate off to the side of the road... all in all though could really use some ideas/assistance!
Cheers thanks for reading my poorly formatted paragraphs
Josh
Josh
