Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old May 22nd, 2020, 10:19   #1
Jodyjames
Default P0299 underboost
Bought car not running. DPF was plugged, deleted and installed 0.5 tune. Drove it for first time last night and no power, CEL, lots of black smoke. Obviously not making boost. P0299 came up, everything visually looks good on turbo, and hoses . Am I missing something. Decent mechanical knowledge but absolutely new to these cars.
Jodyjames is offline   Reply With Quote
Old May 23rd, 2020, 18:08   #2
redbarron55
If I remember correctly the P0299 is the waste gate actuator on the turbo.
On the 2.0 TDI you can replace it without pulling the turbo, but you will have to work for it and bend a 10 mm wrench to fit.
There are some suggestions here about it.
Search is your friend, IIRC.
redbarron55 is offline   Reply With Quote
Old May 24th, 2020, 17:32   #3
Will27
If you are happy you have no boost leaks and the vacuum lines are hooked up correctly, follow this video: https://www.youtube.com/watch?v=Nl66nCaOlI0
This is an excellent video from Richard, one of the members here on testing the vacuum side of the system to pinpoint where the problem is.
Will27 is offline   Reply With Quote
P0299 Underboost Issues SLVVR6 VW MKV-A5 Golf/Jettas 1 September 6th, 2015 18:30
P0299 Underboost flashmayo VW MKIV-A4 TDIs (VE and PD) 21 September 20th, 2013 18:15
P0299 turbocharger underboost?? deltatech TDI 101 2 November 24th, 2012 15:00
What to do w/ P0299 turbo underboost? rustybolts VW MKIV-A4 TDIs (VE and PD) 0 September 2nd, 2012 10:06
p0299 turbo underboost and smoke Mariusz257 VW MKIV-A4 TDIs (VE and PD) 9 March 9th, 2010 20:43
Page generated in 0.11307 seconds with 11 queries
[Output: 56.80 Kb. compressed to 51.68 Kb. by saving 5.12 Kb. (9.01%)]
