Old May 22nd, 2020, 06:40   #1
Poor King
Default Swap all the things
Mk4 to MK2 TDi-M swap question (super noob). I would like to swap everything I possibly can from '03 Jetta into my '92 Diesel Jetta; this means swapping in the full dash and I will be adding an aftermarket fuel tank in the trunk.
With this scenario, why would I need the CE2 wiring at all. Couldn't I just make the mk4 wiring work for evrthing?
Poor King is offline   Reply With Quote
Old May 22nd, 2020, 06:46   #2
eddieleephd
Fuel Economy: 38mix / 47@70-75
Well I'm not sure everything will fit, the body is not the same size so the dash is assumably to long and mounting points are different. I believe even the seats are to big as the width is at least 6" narrower.
Look in my signature for the TDI search and search for swapping mkiv seats to mkiii
Sent from my moto g(7) power using Tapatalk
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, Bosio DLC 1019's PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is offline   Reply With Quote
Old May 22nd, 2020, 06:47   #3
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Post this in the forum meant for this and you will probably get a better response.
http://forums.tdiclub.com/forumdisplay.php?f=63
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod | Homelink visor
VCDS-HEX/CAN available Houston metro area.
jokila is offline   Reply With Quote
Old May 22nd, 2020, 07:50   #4
Poor King
Thanks for the replies; I'll head on to the conversions forum.
Things I'll miss and things I won't chasfos Dieselgate - VW Group Emission Scandal 0 September 7th, 2017 03:39
ALH engine swap-things to do while it's out 50harleyrider VW MKIV-A4 TDIs (VE and PD) 8 November 6th, 2014 18:11
Things I learned today and things that happend VaanBasch VW MKIII-A3/B4 TDIs 0 August 29th, 2014 18:35
3 quick things, ECU swap, Aftermarket Foglights, No Drill License Frame tdiinmyeye VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 5 December 23rd, 2011 08:01
Do you need pics of any specific things from a Mk2/corrado swap? G60ING TDI Conversions 11 February 7th, 2007 19:31
Page generated in 0.12723 seconds with 11 queries
[Output: 63.35 Kb. compressed to 56.80 Kb. by saving 6.56 Kb. (10.35%)]
