Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old May 18th, 2020, 09:30   #1
Bastone007
Default 2006 jetta wagon mk4 bew timing belt
I hope someone can give me a positive answer. I just did my timing belt on my car.When I completed the job,I turned the crank by hand two times and noticed cam pin wont go back in. Now in hind site, I noticed my crank lock tool is a bad tool, with the mark two teeth to the right of where it should be.Did I bend any valves?Im going to realign to where it should be, Im just worried if I may have bent valves. I didnt feel any contact when I hand turned the engine over twice.
Bastone007 is offline   Reply With Quote
Old May 21st, 2020, 13:14   #2
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
If you turned it over by hand and didn't feel abnormal resistance other than compression, you didn't bend any valves.
Proudly installing things where they're not supposed to go since 1996!
Windex is online now   Reply With Quote
Timing Belt replacement 2006 Jetta Wagon TDi dmikaluk VW MKV-A5 Golf/Jettas 10 July 12th, 2011 05:05
Timing Belt on 2006 BEW Engine Sky King TDI 101 42 November 20th, 2010 09:30
Timing Belt on 2006 Jetta Wagon blairkelly VW MKV-A5 Golf/Jettas 8 September 26th, 2010 18:53
Timing Belt Tensioner question on 2005 Jetta Wagon BEW Shenandoah TDI 101 4 July 6th, 2008 17:54
Page generated in 0.12687 seconds with 11 queries
[Output: 51.74 Kb. compressed to 47.71 Kb. by saving 4.03 Kb. (7.79%)]
