Old May 12th, 2020, 09:23   #1
travis45
travis45's Avatar
Default High quality oil for high horsepower application
Hello,
Just about to crank my rebuilt common rail engine for the first time and want to select an appropriate oil once it's broken in. Earlier I've been running Rotella T6, but I'm afraid that the cheapness will shine through.
In this engine I'll be shooting for north of 300hp with KS sputter bearings, stock oil clearance.
Was looking at a couple Luiqi Moly options, maybe Top Tech 4100 5w40 or Leichtlauf 5w40.
Or perhaps Motul 8100 X-cess 5w40.
Obviously DPF is deleted so that is a non issue spec wise. Just want a high quality oil to protect my build.
Any input from oil experts is appreciated.
Respectfully,
Travis
14 Sportwagen. 267hp last time at the Dyno.
travis45 is offline   Reply With Quote
Old May 12th, 2020, 09:34   #2
turbobrick240
turbobrick240's Avatar
I wouldn't call myself an oil expert, but the 5w40 T6 is more than adequate, imo. Just don't push it much beyond 10k miles. If you are going to be running hot laps at the track I'd consider something like Mobil1 15w50.
turbobrick240 is online now   Reply With Quote
Old May 12th, 2020, 09:38   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Every oil thread synopsis:
"I have used A brand oil and it works great!"
"I have used B brand oil and it works great!"
"A brand oil sucks!"
"B brand oil sucks!"
"You're all idiots, C brand oil is better than any of them!"
"You should run Amsoil for everything, including your lawn mower!"
"Everybody is stupid!!!"
Like we really need another oil thread.
oilhammer
www.cardocautomotive.com
Old May 12th, 2020, 12:46   #4
You might want to try Total Quartz Racing 10w50 oil. Maybe withstand heat better. I used to run Quartz 7000 10w50 in my ALH on track days.
2002 Jetta wagon, 412K, RC3+; 1993 Mercedes-Benz 300D 2.5, 199K; 1997 Passat, 289K; '99.5 Golf, 262K; 2011 335d, 64K; 2015 Golf Sportwagen, 14K. Principal, http://www.idparts.com
Old May 12th, 2020, 18:43   #5
travis45
travis45's Avatar
I think I could have worded my question better. I'm more interested in learning about the real world results from varying from OEM oil weights rather than the Ford vs. Chevy arguments about the brands of oil.
I've heard rumor that T6 has had some kind of formula change. Not sure if it is true or not. I've used it for years and never had any kind of issue. But the $15 a jug price makes me wonder. IDK, maybe it's fine...
I don't have a good understanding of what it means or if it is a good idea to stray from the OEM oil weights.
If I'm running the stock bearing clearances and run a heavier oil, is that safe? What about something like a Mobil 1 Racing 0w50?
This car really won't be used in winter, and I have added an oil cooler. Will be for spirited weekend abuse and occasional track days. Appreciate the suggestion for the 10w50 IBW. Will take a look.
Appreciate the advice.
Travis
Old May 13th, 2020, 03:00   #6
I think the higher top number would be helpful, as the engine will generate more heat than stock. When I was running my ALH on the track I'd regularly see coolant temps in the 240-260 range. Didn't have an oil temp gauge but that got hot, too.
Rotella is different from years ago. It's been reformulated to be a low ash oil so it can be used in diesels with particulate filters. Don't know how it's affected the rest of its performance. Still a good oil, however. Delvac, which is similar, is more likely the same as the "old" Rotella.
Old May 13th, 2020, 04:57   #7
TDI Greg
I would run a Euro spec oil -- Castrol, Luqimoly, or Amsoil, etc and if you are racing just change the oil more often - at least every 5k.
--If it's smokin it's broken--
Independent Amsoil Dealer # 5692728
2002 Jetta TDI--VNT17 Turbo, Colts Stage 2 Cam, SB Stage 2 Daily, Sprint 520's, HV Oil Pump, ARP Headstuds, Kerma TDI Tuning, & ECS Street Coilovers.
TDI Greg is offline   Reply With Quote
Old May 13th, 2020, 05:15   #8
travis45
travis45's Avatar
IBW, when you say the top number, do you mean first or second? The 5 in 5w40 or the 40?
Thanks,
Travis
Old May 13th, 2020, 05:27   #9
The 40.
Old May 13th, 2020, 09:06   #10
sloinker
sloinker's Avatar
Here is the site to go to for oil questions:
https://www.bobistheoilguy.com/forum.../forum_summary
I would contact this place for oil if it was my car. Get what you are paying for:
https://www.hploil.com/motor-oil
sloinker is offline   Reply With Quote
Old May 13th, 2020, 12:45   #11
CleverUserName
Use an appropriate break in oil for the first run. After it’s broken in, drain and refill with an appropriate HP diesel specific oil. The required viscosity can be verified by observing your operating oil temps, extra heat requires a higher viscosity to maintain the same film thickness.
Notable mentions:
1. Driven DP40 5w40
2. Renewable Lubricants BioSyn HD 5w40 or 15w40
3. Redline 15w40
4. Phillips Triton ECT 5w40
5. Amsoil Dominator 20w50
Or you can just go to Walmart and buy the cheapest diesel oil on the shelf and hope for the best.
CleverUserName is offline   Reply With Quote
Old May 13th, 2020, 14:28   #12
travis45
travis45's Avatar
Thanks for the links and comments.
Old May 13th, 2020, 22:18   #13
3L3M3NT
3L3M3NT's Avatar
This is what I'll be running in my RTDI once James gets it back together.
https://products.liqui-moly.com/oils...-10w-60-1.html
I used to run this if you're looking for another option.
https://www.schaefferoil.com/9000-racing-oil.html
You could also try this oil.
https://www.motul.com/us/en-US/products/sport-5w50
Fix if you're using Chrome: Chrome fix
Firefox fix
RTDI Build Thread
October 19th,2019 Cruise/GTG in Sturgeon Bay, WI
3L3M3NT is offline   Reply With Quote
Old May 14th, 2020, 07:55   #14
travis45
travis45's Avatar
3L3M3NT, thanks for the links.
Are you running stock oil clearances on your rod and main bearings?
Old May 14th, 2020, 08:39   #15
3L3M3NT
3L3M3NT's Avatar
I honestly don't know, but I'm sure that James would be able to answer that question. If I had to guess I would say yes my engine has stock clearances. If I remember correctly there was a picture from the original engine build.
http://forums.tdiclub.com/showpost.p...7&postcount=32
Firefox fix
RTDI Build Thread
Anyone have a high horsepower beetle? ss04vv TDI Power Enhancements 13 February 13th, 2012 12:43
Engine Oil Level - How High Is Too High? TheKid7 TDI 101 31 April 26th, 2011 10:09
FS High Quality Tranny oil cooler, Fuel Pump evangelos Private TDI Items for Sale/Wanted 2 February 26th, 2007 11:11
High Quality Motor Oil Prices Rise SkyPup Fuels & Lubricants 1 December 5th, 2000 13:15
A High Quality Conventional Oil at a Low, Low Cost Ric Woodruff Fuels & Lubricants 8 June 9th, 2000 11:02
Page generated in 0.17658 seconds with 11 queries
[Output: 130.95 Kb. compressed to 109.24 Kb. by saving 21.71 Kb. (16.58%)]
