Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW Touareg TDIs
VW Touareg TDIs This is a general discussion about Touareg TDIs. Non TDI related postings will be moved or removed.
Old April 21st, 2020, 19:43   #1
maxTouareg
Fuel Economy: 32/22/15 MPG (hwy/city/tow)
Default 2016 Teg sound system - what is it?
Greetings,
I've used the VCDS cable and Ross-Tech software to interrogate my Touareg.
  • Vehicle type = BP-VW52 (7P6), Sport Edition
I wish to upgrade my sound system, but I'm trying to understand what sound system I have. Just so I know what I need to purchase. IE: MOST bus adapter.
Note - Using the VCDS I was able to change the radio EQ setup (Dynaudio configuration I think). Sounds a little better.
But:
  • Does the Teg use the MOST bus or not?
  • Does the Teg have an audio amp anywhere?
  • I don't think its using a digital subsystem?
Any feedback is appreciated.
Kind regards,
maxTouareg is offline   Reply With Quote
Old April 28th, 2020, 11:39   #2
joep1234
I had a 2015 Touareg brochure and it said that the system was a Dynaudio system. I Googled it and they are a Danish speaker manufacturer. The '04 and '05 Touaregs that I had were very nice and sounded great. I currently have 2 '15 Q5 TDI's. My wife's car has the B&O system and I have the standard radio but they both sound good. Here is a link for more info: https://www.dynaudio.com/car-audio/car-models/touareg
'04 Beetle TDI w/BEW and DSG
joep1234 is offline   Reply With Quote
Old May 15th, 2020, 17:47   #3
mannytranny
mannytranny's Avatar
TDI(s): 02 Jetta
There's an adaptation you can do to the stock system that supposedly makes a huge improvement. It's as if VW detuned the stock audio system to upsell the Dynaudio package. Check out clubtouareg for details.
mannytranny is online now   Reply With Quote
Sound system. usethefarce Upgrades (non TDI Engine related) 3 February 15th, 2013 14:35
sound system ryan74701 TDI 101 0 December 13th, 2010 13:22
Sound System DGS Upgrades (non TDI Engine related) 0 May 27th, 2010 08:18
Sound System Issue jjohns72 VW MKV-A5 Golf/Jettas 16 July 25th, 2007 18:21
Sound System Radu TDI 101 2 March 18th, 2004 17:36
Page generated in 0.11331 seconds with 11 queries
[Output: 57.99 Kb. compressed to 52.54 Kb. by saving 5.44 Kb. (9.39%)]
