Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW Touareg TDIs
VW Touareg TDIs This is a general discussion about Touareg TDIs. Non TDI related postings will be moved or removed.
Old April 10th, 2020, 23:02   #1
peegeez
Fuel Economy: 21 MPG HWY; 28 MPG HWY
Default Setting the cam gear on V10 TDI
I did replace my cam shafts with the engine still in the vehicle. It went smoothly up to the point where I had to set the cam gear, lined up the mark etc. I put the car back together and it fired up and runs great. However, according to my VCDS I am getting the P0341 error code. I think I installed the timing gear a 180 degrees out. Is there a definitive way to know which way the gear goes in? I can not lock in the crank but I can lock in the cams. So, since I can not lock the crank I can be be out 180 degrees. My question is do you set the gear with the cam lobes on the #1 cylinder pointing downward or with the cam lobes pointing upward? If anyone can help me with this procedure it would be greatly appreciated.
peegeez is offline   Reply With Quote
Jetta Timing belt: Cam setting tool too sloppy? notagearhead TDI 101 4 August 7th, 2013 22:05
BRM Cam Torsion setting Green_Streak VW MKV-A5 Golf/Jettas 4 February 17th, 2013 12:37
2004 V10 Touareg TDI with Stage II Cam and Hybrid Turbos addicted TDI Cars for Sale/Wanted 4 October 22nd, 2012 14:03
Cam setting tool and line on fly wheel septimus TDI 101 6 December 15th, 2010 07:02
Setting Cam Timing Cylinder Head off. merkin TDI 101 6 June 5th, 2007 08:59
Page generated in 0.13920 seconds with 11 queries
[Output: 47.17 Kb. compressed to 44.49 Kb. by saving 2.68 Kb. (5.67%)]
