Old May 16th, 2020, 20:32   #121
J.Klassen
Hey guys and girls, sorry its been awhile. I've been a little busy working on some of my friends vehicles. Anyway time to carry on, I really need to get this back log of pics posted! We are going all the way back to the fall of 2018 for this one. I insured the truck for the coming winter and took it for a little test drive. Just as I was pulling back into the driveway the coolant temp spiked right to the top of the gauge. I turned the truck off and popped the hood to find this lovely surprise!
The upper rad hose had come off because the plastic end tank cracked right around where the hose clamp was. I going to say it was because of old age and not because the hose clamp was too tight.
The solution of course.... is not to buy a new rad, but to go looking in my stash for something suitable to fix it with. Wouldn't you know it I had a damaged cummins intercooler!
Time to remove the plastic endtanks and make them out of aluminum like they should have been.
The bottom was quite clean.
And the top only had a little rusty residue that came of easy with water and a toothbrush.
Chopped one of the cummins endtanks off and started to compared it to the plastic tank. Almost good for lentgth, but its going to need some pretty good surgery.
J.Klassen is offline   Reply With Quote
Old May 17th, 2020, 14:58   #122
J.Klassen
Here's all the pieces to make the bottom tank.
Welded up and ready for test fit on the rad
Test fit looks good. Time to make it all one piece.
The top tank is much the same except that I added a point where I can add coolant/ bleed air.
Mocking up the top tank.
It passed the leak test so I put it all back together, ready to go back into the truck.
Old May 18th, 2020, 07:02   #123
evguy1
Jason, I do enjoy seeing your fab work. I shipped another Nissan kit to a fellow near you last week, hopefully he will do a build thread as well.
2000 Jeep XJ / BEW http://www.cherokeeforum.com/f46/2000-tdi-blacky-205238/
2008 Dodge Dakota / Cummins ISB170 https://tdconversions.com/dakota-cummins-isb170
2005 Ford Ranger / 1.9 TDI https://tdconversions.com/ranger-1-9l-tdi
evguy1 is offline   Reply With Quote
Old May 18th, 2020, 19:59   #124
J.Klassen
Thanks! I hope it gives people ideas for solving problems that they come across. That's great that you sold another nissan kit. Gotta catch up to those toyotas and jeeps haha. I'd like to meet this guy sometime. Maybe you could send me an email if he is interested.
Old May 31st, 2020, 19:47   #125
J.Klassen
After that winter was over I decided that the little diesel was shaking the truck a bit too much. The solution was to replace the gas engine mounts with hydraulic ones. The ones from a BHW would be good but were kind of expensive to get from vw. As far as I could tell all the aftermarket ones for a BHW look the same as oem but are not fluid filled like the original and won't do the same job. So I got some mounts form the local Jeep/Dodge dealer that were for a Jeep Liberty CRD.
Passenger side gas mount setup
CRD mounts. Turns out the one with the heat shield is cheaper so I just ordered two of them
Old frame mount location is going to have to go!
New frame mount tacked to the frame rail
Test fit CRD mount and now its time build between the mount and the engine block
Old May 31st, 2020, 19:51   #126
J.Klassen
Finish weld, paint and install.
It's tight in there but I can still get the starter out.
Old May 31st, 2020, 20:01   #127
J.Klassen
Driver's side is more of the same
Only this time I had to make it so that the mount could be unbolted from above because with the front differential below it the would be no way to get at the bottom bolt.
Final test fit, then paint and install.
tdi into a nissan K line problems happyjohn TDI Conversions 3 December 5th, 2014 04:51
nissan sentra-tdi knarfy Sightings 0 May 9th, 2010 10:33
Nissan 240SX TDi Swap frucknut TDI Conversions 9 November 24th, 2007 18:54
TDI IN A 94 NISSAN pickup dustinr TDI Conversions 9 April 5th, 2007 10:51
Trade a 97 Nissan truck with 30k for a TDI mittenmotor TDI Cars for Sale/Wanted 0 August 20th, 2003 21:18
Page generated in 0.15071 seconds with 11 queries
[Output: 91.68 Kb. compressed to 81.51 Kb. by saving 10.17 Kb. (11.10%)]
