I've got a whine from the transmission that I only hear when decelerating in gear, mostly in 2nd. It's not loud, but I'm used to modern transmissions being about silent in forward gears. Normal? Haven't checked oil but it's not leaking.
was not trying to talk down on you or anything, i have no way of knowing your mechanical aptitude so i mentioned DIY and alternatively asking lube tech to look at fluid. I wouldnt shy away from changing it but i might shy away from using non-VW stuff in it. You have to admit that describing car sounds with text can be kind of vague though.I'm a mechanic and yes, I do my own oil changes. Hesitant to change trans oil preventatively, because my experience has been that half the time it does nothing but make the synchros stiffer.
In this car? I haven't done it yet, and based on its mileage and previous owners, I believe it has never been changed.What did you use for gear oil last time?
