Old July 10th, 2015, 16:31   #1
PredatorVI
Unhappy Turbo outlet (hose to intercooler) blowing off
I have a 2006 Jetta TDI. The turbo disintegrated and was replace on March 6th.
A few weeks ago I changed the air filter and fuel filter (it had been a while), but before then I was hearing some odd hissing noises but didn't think much of it.
A week or so after replacing filters, it threw a P0101 code and the MAF sensor was replaced and the hissing noises continued (but were louder) and more codes were thrown (not sure what codes). The mechanic then found that the hose going to the intercooler from the turbo was split.
He replaced it but the new one keeps blowing off on the turbo end. The tube is a newer one made of silicon instead of rubber. They swapped it with a different new one again (direct from VW), but it still is blowing off.
The shop works on a lot of VW's and has been very knowledgeable and great to work with but have never seen a tube blow off like this. I believe they replaced the 'U' clip that holds it in (he showed me the old one). I can't imagine the new turbo, tube or clip are the root cause, but I'm fishing for additional options anyway for my own sake. I'm also wondering if the old tube split because of overboost, but I'm not sure.
Any thoughts? He's checked for overboost, but it doesn't seem to happen before the tube blows off.
Other things I've read about include:
- problems w/ variable geometry vanes/actuator/settings (but wouldn't wastegate bleed off excess if this was a problem?)
- wastegate problems (wouldn't overboost code be thrown if this is not working?)
- Bad clip (it's new...could it be bad or malformed?)
- Worn tabs on tube (but this one is new)
I'm open to looking at any other suggestions.
2006 VW Jetta TDI/White Ext/Black Int/5 spd
2000 Ford F-350/Crew Cab/Diesel/Dually
PredatorVI is offline   Reply With Quote
Old July 14th, 2015, 14:57   #2
GreenLantern_TDI
GreenLantern_TDI's Avatar
Fuel Economy: Mid 40s
Never heard of overboost causing such an issue. I would replace both sides of the connection. Hose clip and its female counter part.
2015 Golf SEL. Malone DSG Tune. H6 AGM East Penn Battery. Frost Heater. Ares Skid Plate. Fumoto Valve. PentoIII.
GreenLantern_TDI is offline   Reply With Quote
Old July 14th, 2015, 17:26   #3
Seatman
Seatman's Avatar
Fuel Economy: No idea
And make sure that it's fitted properly, those clips can be awkward and the pipe will never stay on if it's not bang on. Mine kept popping off at the connection between the outlet and the pancake pipe, in the end I stuck a couple of self tapping screws through it which has cured it.
But yeh, wear and tear and off they pop.
Seatman is offline   Reply With Quote
Old March 11th, 2016, 20:22   #4
Nevada_TDI
I have a Stage 3 tune from my VNT-15 and .205 nozzles that I just removed. Just this afternoon my new turbo kept blowing off the "clip" section for the IC input. Two self-tapping screws fixed the problem; I hooked a 17/56 to stock piping but with the same tune I didn't believe a "blowout" would occur. The .230's I just installed really work well with this turbo, and Stage 4 or 5 is due very soon. The motor I took the injectors out of dyno'd at 187 wheel hp running 26 pounds of boost with an S7.
Nevada_TDI is offline   Reply With Quote
PD blowing Turbo hose off AndyBees VW MKIV-A4 TDIs (VE and PD) 16 September 21st, 2016 13:36
WTB - Before Thanksgiving - VNT15 Turbo Outlet Hose & Oil Drain Hose Fix_Until_Broke Private TDI Items for Sale/Wanted 5 November 21st, 2013 21:41
ALH Turbo Outlet Hose ? markward TDI Conversions 4 September 8th, 2009 09:24
turbo outlet hose removal? larsbar VW MKIV-A4 TDIs (VE and PD) 2 November 24th, 2007 14:15
Stock turbo outlet hose woofie2 TDI Power Enhancements 5 April 30th, 2007 08:24
Page generated in 0.08184 seconds with 11 queries
[Output: 64.82 Kb. compressed to 58.18 Kb. by saving 6.64 Kb. (10.24%)]
