Old June 11th, 2015, 20:59   #1
INISLDR
TDI(s): 2002 Jetta
Fuel Economy: 47-49
Default hacked odometer
Well I had my MK4 up for sale and the buyer pulled a carfax. Apparently the PO had rolled back 100K off the odometer. Is there anyway to verify this? Could the carfax be mistaken?
2002 Jetta TDI at 173,000 miles.
1997 Quigley with the 7.3 PS at 134,000 miles.
INISLDR is offline   Reply With Quote
Old June 11th, 2015, 22:06   #2
JDSwan87
Black Swamp Thing
JDSwan87's Avatar
Thr Carfax could be mistaken, all it takes is one of the reporting shops to have a Freudian slip and BAM there's an extra 100k miles. Is there a big jump in odometer readings in a short period of time? Also some states, like Michigan, don't report mileage on a vehicle over ten years old. The slot is simply blank.
Stella (Mine now): 2005 Shadow Blue Jetta Wagon TDI 09A
Mods: RC1. VCDS HEX-CAN USB (near Toledo, OH)
JDSwan87 is offline   Reply With Quote
Old June 11th, 2015, 22:11   #3
JSWTDI09
JSWTDI09's Avatar
Find somebody with VCDS. Your mileage is stored in the instrument panel and in the ECU. VCDS can read the ECU mileage and you can compare it to the instrument panel. If they are the same, your odometer has not been rolled back. If they are different, it could be several things, but if it is off by 100k miles, somebody rolled the odometer back by 100k.
Have Fun!
Don
1966 MGB Roadster (just for fun)
JSWTDI09 is online now   Reply With Quote
Old June 11th, 2015, 22:25   #4
Wankel7
Wankel7's Avatar
Can you alter ECU mileage?
Wouldn't you need a VagTacho to alter cluster miles?
2003 Jetta Wagon 5 speed
DLC520, Audi Avant Rear Wiper, .658 5th gear, FX-R HID Retrofit, Philips DRL9 , Atlas skid plate, trailer hitch, ventectomy, Half FIS Euro Cluster, Frostheater, ceramic tint, Scangauge II, and EGR deleted.
VCDS -HEX/CAN & VagTacho available
Wankel7 is offline   Reply With Quote
Old June 11th, 2015, 22:46   #5
JSWTDI09
JSWTDI09's Avatar
Anything can be hacked (altered). However, changing the mileage in the ECU would require different tools and different knowledge than just the instrument panel. Therefore it is unlikely (but not impossible) that they bothered to change both locations
Yes, or some other similar tool. I have no idea what kinds of nefarious tools are out there for chop shops and other automotive bottom feeders.
Have Fun!
Don
Old June 12th, 2015, 04:33   #6
INISLDR
TDI(s): 2002 Jetta
Fuel Economy: 47-49
Unless of. Course somebody swapped out the dash and the ecu from the same car. Then they would match. I guess I would need to see the report.
Old June 12th, 2015, 05:31   #7
supton
supton's Avatar
Fuel Economy: 53/46/33
Carfax can be wrong.
Recently I got interested in a Corolla for sale at a dealer. Went in, and there was a big discrepancy between what their computer said and what the odo said. No biggie, and walked on the car due to price. Later I checked their website, and the error still existed. And Carfax took note of that, listing a discrepancy.
Two weeks later, the discrepancy was fixed at Carfax and the dealer.
Speaking of which, I once claimed an accident on my Jetta. Minor accident, no police report. But an insurance payout. Not listed on the Carfax for my car. I don't think the dates for when I got emissions testing lined up properly either on their list.
Not saying I'd ignore a Carfax, just that it's easy to goof.
'04 Jetta Wagen 5spd GLS, 314kmiles, Koni Red's, SBC stage 2 clutch, VNT17, RC2 sold
'11 Camry base 6spd manual, 95k, wife's
'10 Tundra double cab, 4.6L, 95k, mine
supton is offline   Reply With Quote
Old June 12th, 2015, 07:00   #8
jettawreck
jettawreck's Avatar
Probably easier to hack CarFax than the cluster.
I bought a 2003 Jetta 1.8T wagon w/124K miles on it. CarFax shows dealer maintained regularly. Dealer has no records of ever having the car in the shop, or any of their branches other than front fender and rear hatch replacement under corrosion recall.
Question is, is the VW service dept wrong or has the independent low life seller/dealer fabricated an elaborate CarFax report??
I don't put much faith in CarFax.
2004 Cadillac SLS (wife's)
Old June 12th, 2015, 07:36   #9
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Originally Posted by jettawreck View Post
Probably easier to hack CarFax than the cluster...................
smart
Old June 12th, 2015, 13:17   #10
fxk
BMW also stores the mileage in a second place - the Lighting Control Module.
The odometer shows a dot in the lower left corner of the odometer if there is a discrepancy of the two.
That also means that if you have the instrument cluster out of the car (for repair) and one drives it x miles, the dot will show up. Basically, no one will touch the car with the dot showing.
Does VW have a similar "alerting" system?
frank
fxk is offline   Reply With Quote
Old June 12th, 2015, 15:50   #11
mittzlepick
mittzlepick's Avatar
Fuel Economy: 1175 record tank
ecu if original will show true. cluster may have been changed out with no on the wiser an owner ago or previous owner not revealing. a cluster swap needs a dealer to make it work i think due to immobilizer. i can sell you a 134k cluster if you want even less miles:.)
mittzlepick is offline   Reply With Quote
Old June 12th, 2015, 16:04   #12
JDSwan87
Black Swamp Thing
JDSwan87's Avatar
OK here's a slightly relevant question, if someone runs 5000 miles on the non original ECU, does that 5000 miles get "burned" onto the original ECU when it is re installed? I'm asking about the issues swapping ECU's with different tunes could cause in regards to mileageon the odometer/ecu...
Old June 12th, 2015, 16:20   #13
JSWTDI09
JSWTDI09's Avatar
I am pretty sure that each ECU keeps it's own data, it does not get it from the cluster or anywhere else in the car. Therefore any replacement of either ECU or Instrument cluster will cause the 2 to disagree about mileage. The only exception I am aware of to this rule is a new cluster. A new cluster can have the mileage set to whatever you want (or need), but this only works for clusters with under 100km (IIRC) on the odometer.
Have Fun!
Don
Old June 12th, 2015, 16:36   #14
AndyBees
AndyBees's Avatar
Seems the VAG Tacho shows Kilometers ,,,, I do remember seeing like 120k more on a 2002 Jetta Gasser that I was helping with key programming. Then I noticed the number was in Kilometer as opposed to miles...
Just saying!
This is the TDI Club, a place to share experiences & ideas, ask for help, etc. Welcome Newbies! Sarcastic and condescending posts shouldn't be welcome.
Old June 12th, 2015, 18:25   #15
INISLDR
TDI(s): 2002 Jetta
Fuel Economy: 47-49
I am interested in searching the ecu for mileage info. Can somebody point me in the right direction? I have a VAG-COM cable and VCDS. Just need to know where to look...
Also after looking at the Carfax it appears that the owner before me rolled back the odo 100k. They only owned it for 4 months and they had it smogged right before they sold it to me. I'm actually surprised at the condition of the car for almost 300k miles. Very simple and robust vehicle. Of course now I have to deal with this mess trying to sell it because I cannot pass on the lie to the next buyer.
I would also like to roll the odo forward ( if possible ) to the correct reading if I can in fact pull the mileage from the ecu...
1 Timothy 6:10
For the love of money is the root of all evil: which while some coveted after, they have erred from the faith, and pierced themselves through with many sorrows.
2013 Jetta odometer and trip odometer Chet57 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 2 October 4th, 2013 18:34
My account was not hacked LustForTDi TDI Fuel Economy 16 September 1st, 2010 12:57
Ive just hacked off my backbox Little Pickle TDI Power Enhancements 10 February 8th, 2010 17:02
tdiparts got hacked? edstreet General Automotive 9 April 8th, 2009 09:44
Help, Odometer, trip odometer and clock blank and run car MadDogBrenner TDI 101 2 February 19th, 2009 15:33
Page generated in 0.16822 seconds with 11 queries
[Output: 130.72 Kb. compressed to 108.95 Kb. by saving 21.77 Kb. (16.65%)]
