Old November 4th, 2014, 04:53   #1
50harleyrider
Default ALH engine swap-things to do while it's out
Got what appears to be a good engine out of an '01 250k donor. I drove it home 350 miles and it has plenty of power. It's an automatic and some motor oil is dripping out of it-appears to be main seal. Here's my path forward and wanted comments/recommendations: Flywheel is coming off as it's going in a manual car so I plan a rear main seal, oil pan reseal, check rod bearings,check cam and lifters. Is there anything else I should do or look for? Maybe oil pump? TB is only 5k old and looks great but unfortunately I don't know if the water pump was replaced. Quarter of a million miles concerns me so I'm a little antsy. It didn't use any oil or coolant and the head gasket isn't seeping. Don't see any other seeps.
50harleyrider is offline   Reply With Quote
Old November 4th, 2014, 05:04   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
At that mileage, if you are going to do the timing belt and water pump and oil pan reseal anyways, go ahead and replace the oil pump chain and tensioner. It is quick and easy at that point.
You'll just need a front crank seal, crank bolt (one-time use), the chain, and tensioner. It is right under the front sealing flange.
The rear crankshaft seal will be integral with the flange.
I'd not worry about the cam and lifters myself, beyond just a quick visual peak. And I certainly wouldn't mess with the actual oil pump itself, or any of the bearings.
oilhammer
www.cardocautomotive.com
Old November 4th, 2014, 06:11   #3
Kraiger
Kraiger's Avatar
TDI(s): 02 jetta
Fuel Economy: 45mpg Jetta, 65mpg Cruze....oopps
I second oilhammer. but just my .02 is for the price of a stock cam and lifters from idparts, id replace them. I mean the timing belt will already be loose and then you will not have any worries for at least 100k.
2014 Chevy Cruze Diesel 65mpg
2000 Jetta TDI shop car 50mpg
Kraiger Automotive Service LLC.
Lima, OH VCDS/TDI service.
Kraiger is offline   Reply With Quote
Old November 4th, 2014, 06:50   #4
50harleyrider
Is there any way to inspect the water pump to see if there are any signs it may be fairly new? I hadn't planned on wp replacement if I didn't have to. I figured with only 5k on the new tb, wp was replaced then too. Maybe a risky assumption?
Old November 4th, 2014, 07:19   #5
A5INKY
Fuel Economy: pretty good
A visual inspection of the WP is a good idea. A new pump 5K ago should still look pretty new. More than half of pumps I change during TB jobs are leaking at least a little through their weep hole.
Then again, with the engine out a TB job sure would be easy.
With the age and mileage, I would consider an IP pump reseal while it is out too. Even pumps that are not leaking fuel externally can leak air into the pump allowing a loss of prime in extreme cases.
A5INKY is offline   Reply With Quote
Old November 5th, 2014, 19:33   #6
50harleyrider
Thanks all-great advice.
Old November 6th, 2014, 03:01   #7
CourierGuy
CourierGuy's Avatar
Fuel Economy: 57.65/41.70/32.76; 80%+ City mileage
Im a fan of changing the motor mounts... while an engine is all the way out. Nice suddle improvement.
GOLF:OMI, BV39@22psi, 2.5" Plumbing, 4Slice Toaster SMIC, Kerma IM, P&P Head, Colt Stage2, DLC1019s, Buzzken 2.5 Exhaust, Malone Stg4, Custom Oil Catch Can, Shine Springs/RSB, Koni FSBs, TT LCAs, SB Stg3 Endurance, Peloquin LSD, TT SS, Evo skidplate, 205/65r15, GLI Leathers, Boost/EGT/Oil PSI/temp gauges, mild ice, !DRL/EGR/IC Vent Grill. GOLF(Winter car): UNITronic tune, .216s A Corolla story for every day
CourierGuy is offline   Reply With Quote
Old November 6th, 2014, 17:52   #8
AndyBees
AndyBees's Avatar
I agree with Oilhammer about the bearings... if you inspect, you're going to need new bolts. Many ALH engines are pushing toward 500k miles with the OE rod bearings!
Only 5k miles on the water pump, I'd not worry about it at all! Of course, you are there, take a look for a leak!.......... seriously doubt you will see any evidence of a leak!
Once the engine is ready to set in, I'd pressure wash it!
This is the TDI Club, a place to share experiences & ideas, ask for help, etc. Welcome Newbies! Sarcastic and condescending posts shouldn't be welcome.
Old November 6th, 2014, 18:11   #9
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
I'd do as much engine work as is possible BEFORE pulling it from the donor. That way you won't be searching for a swap related issue when it could be a replacement related issue. Keep it simple and get the replacement stuff done and sorted while it's still drivable as an auto, then you'll be able to eliminate any engine internal components when you sort out a post-swap issue.
Yeah, the rear main and other stuff should be done during the swap, but stuff at the other end of the crank should be done now before yanking it out.
Svante Arrhenius 1896
Help me understand my engine map (1.9L ALH) (Or I intend to do stupid things) Sbeghan TDI Power Enhancements 735 April 18th, 2019 08:45
ALH 1.9 golf engine swap mtstclair VW MKIV-A4 TDIs (VE and PD) 9 September 20th, 2013 19:25
No communication with k-line with engine running: ALH engine swap hans j OBD Scanners 1 October 7th, 2012 18:39
ALH to AGR Engine swap 07GTI72 TDI Conversions 1 July 24th, 2008 05:34
WTB: Need a few things for an ALH engine marvinall Private TDI Items for Sale/Wanted 1 September 15th, 2007 16:22
Page generated in 0.15237 seconds with 11 queries
[Output: 93.17 Kb. compressed to 79.75 Kb. by saving 13.42 Kb. (14.41%)]
