Old March 22nd, 2020, 12:44   #391
solovey
Hey everyone.
I'm wondering if this solution is also compatible with my 2014 Jetta TDI 2.0
solovey is offline   Reply With Quote
Old March 22nd, 2020, 12:56   #392
corrado tdi
corrado tdi's Avatar
Fuel Economy: 43ish overall
Yes, this fix applies to 2008-2014 Common Rail TDI worldwide.
Jim Royston
www.dieselgeek.com
corrado tdi is offline   Reply With Quote
Old May 10th, 2020, 08:01   #393
FJ40Jim
FJ40Jim's Avatar
Fuel Economy: 25-52
Default Intermediate gear?
Our 2012 JSW TDI has been flawless for the last 11k miles, bought used in 8/2019 at 132k. Yesterday the MIL came on, scanned w/ VCDS, had P2015 code. Googling somehow turned up this video in German, which clearly shows the inside of the V157 motor.
https://youtu.be/7DvGZDDzPxY?t=273
I thought it would be a good idea to open up the motor to blow the dust out of it and verify its' internal stop is undamaged. That went well, but I now realize the intermediate gear spins in front of a sensor. Does anybody know if the clocking of the intermediate gear matters, or if it's just an RPM sensor to verify to the ECU that the motor is spinning?
Edit: Went ahead and reassembled clean V157 motor with intermediate gear in random position. Fabbed a stopper for arm using a 1/4" shaft collar & stubby screw. Tested with VCDS, worked fine laying on the engine. Installed V157, test ran & restarted engine several times, voltage stays at .760V target when sitting on stop.
To answer my own question: It doesn't seem to matter where the intermediate gear is installed. It just needs to read the RPM of the gear.
When my craptastic spacer fails, I'll be ordering the fix kit from Dieselgeek.
Jim C
01 Golf GLS TDI 5M RC3 racepipe Sprint520 VDOgauges 215/55ZR16 hitch mufflerectomy yadda (mine now!)
12 JSW TDI DSG. EcoHitch, airshox, poly bushings,frostheater (hers)
FJ40Jim is offline   Reply With Quote
Old June 5th, 2020, 08:41   #394
jesus_man
Yay! My turn with the p2015 code! Just a tick over 140k (50k of which are mine), so I suppose it's time.
Will be ordering from dieselgeek today!
2010 JSW TDI DSG in gray with black interior
2009 JSW TDI DSG - sold back to VW
2002 VW Passat Wagon, 6spd, silver Family hauler! - Euro Spec
2006 Jetta TDI Bought 6/25/06 (traded in 10/2009 @ 43mpg
jesus_man is offline   Reply With Quote
Old June 15th, 2020, 05:32   #395
jesus_man
I've installed my dieselgeek hard stop device and now it seems as tho the rpms on the car surge a bit like the flap is trying to find a happy spot and can't. This happens while driving in low rpms. Anyone else experience this?
Old June 15th, 2020, 13:22   #396
FJ40Jim
FJ40Jim's Avatar
Fuel Economy: 25-52
Have you VCDS scanned the vehicle, repaired any codes and cleared all codes?
Jim C
Old June 15th, 2020, 13:43   #397
corrado tdi
The best idea is to start a conversation via email with us so we can send you the troubleshooting email. We ask for a good clear picture of the installed part and any other codes you might/may be seeing before or after the install. Don't respond here but to our email address as we do not regularly monitor this thread.
Jim Royston
www.dieselgeek.com
Old June 15th, 2020, 17:33   #398
jesus_man
Have not ran VCDS but check engine light was gone the morning after the install.
Jim - ill see if I can get you a picture. Thanks!
P2015 / VAG 008215 Intake Manifold Write-up and Replacement T-MILLS VW MKV-A5 Golf/Jettas 26 December 27th, 2019 14:42
2009 P2015 code - intake manifold and flap valves help DIY TerryE VW MKV-A5 Golf/Jettas 43 May 2nd, 2015 10:47
P2015 intake flap motor arm psdowner VW MKV-A5 Golf/Jettas 2 December 25th, 2013 12:49
Intake Manifold Flap Position Sensor Fault Code P2015 pawel VW MKV-A5 Golf/Jettas 0 August 11th, 2013 20:27
p2015 trouble code intake manifold runner sensor/switch????? mikertdi TDI 101 10 October 23rd, 2012 17:45
Page generated in 0.14610 seconds with 11 queries
[Output: 90.33 Kb. compressed to 78.03 Kb. by saving 12.31 Kb. (13.62%)]
