Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Non VW Group Diesels
Non VW Group Diesels This section is for discusion of Non VWGroup Diesels.
Old May 27th, 2020, 12:31   #1036
tomo366
TDI Lifer, Member #131
tomo366's Avatar
Originally Posted by 3turboz View Post
How much does the x drive impact MPG on the 328d?
Do not know never drove a rear wheel drive model
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2015 Jeep Grand Cherokee Overland EcoDiesel
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old June 4th, 2020, 10:50   #1037
pdh
Fuel Economy: 42/49 VW, 38/42 BMW
I brought my 328d Xdrive in last week for the recall. My dealer replaced an "aluminum flex disc". They had the car for 24 hours because he told me the repair parts were VIN specific.
Not a problem since I had a new 330i loaner.
I do not know if the fluid in the transfer case was changed....did not show in the service report which leads me to believe it wasn't changed.
pdh is offline   Reply With Quote
Old June 4th, 2020, 11:12   #1038
mjez
TDI(s): 00 Jetta
Fuel Economy: 47mpg
Sounds like it's an external part that doesn't require draining of fluid. Probably a good idea to do it on your own.
Sent from my PH-1 using Tapatalk
mjez is online now   Reply With Quote
Old June 5th, 2020, 13:28   #1039
pdh
I did it have it changed at 40k and am going to change it again at 80k.
Old June 7th, 2020, 08:28   #1040
3turboz
3turboz's Avatar
Fuel Economy: 37/42/48
I have a deal in the works on a 328d. Owner is upside down and needs to clear the lien before we can complete the transaction. It must suck to have to write a check to sell your car!
There is one I would have rather bought is east TX, but the cost of the travel to make it work just did not make sense.
Is there a bimmer forum where people actually work on their own cars?
Carl - GOLF TDI-Sold, 2014 328d, T1N Sprinter, 280Z Turbo
3turboz is offline   Reply With Quote
Old June 7th, 2020, 09:03   #1041
mjez
TDI(s): 00 Jetta
Fuel Economy: 47mpg
I believe bimmerforums has a diesel community but from what I heard it's mostly about power upgrades, I haven't checked it out myself. Still, you will find a lot of useful information not related directly to diesel. Those cars share a lot of parts.
Old June 7th, 2020, 12:41   #1042
Tin Man
Tin Man's Avatar
Fuel Economy: 51/40/30 TDI PD, 42/37/32 535d, 52/46/42 XE 2.0d
https://www.bimmerfest.com/forums/fo...prune=-1&f=154
https://f30.bimmerpost.com/forums/fo...play.php?f=488
https://www.facebook.com/groups/219258958479539/
'16 535d, '17 XE 2.0d
"We see things not as they are, but as we are."-- H. M. Tomlinson
"Once I make up my mind, I'm full of indecision."-- Oscar Levant
Tin Man is offline   Reply With Quote
Old June 11th, 2020, 06:01   #1043
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
The most active community is NABDOG: https://www.facebook.com/groups/NABDOG/
The best mechanics and tuners in the country are active there. It's not nearly as well organized as this site was in its hayday, but the expertise is there.
2011 BMW 335d - JR 2.8, 600 lb-ft
Blue_Hen_TDI is offline   Reply With Quote
Old June 15th, 2020, 10:34   #1044
3turboz
3turboz's Avatar
OK, pulled the trigger on a 2014 328d sedan. Kind of plain Jane as it has no nav. Has everything else I need though.
60k miles, $12.5k
This is "my wife's car" but since I drive whenever we are together i will get a lot of seat time. She has commented several times already that she likes the way it drives.
BMW life day 2 started with a TPMS warning. All tires are within 1 PSI and a little over inflated, so must be based on wheel sensor data.
Old June 15th, 2020, 14:18   #1045
tomo366
tomo366's Avatar
Mine has almost every option.....And I love the Car!
Old June 15th, 2020, 18:04   #1046
capt_slow
capt_slow's Avatar
Aside from the engine, exhaust system, and DDE module, all the F3x cars have nearly identical ECUs and parts. Bimmerpost and Bimmerfest are definitely good resources. For those that like to wrench on their own cars, ISTA and newTIS are essential.
The transfer case recall replaces the rubber-damped aluminum guibo with a fully rubber one. The facelifted versions should already have it and are not on the recall.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, Driver Assist Pkg, M-Sport Pkg, Premium Pkg, ACC, Side/Top Cameras, Park Assist, Nav, HK
2015 GSW TDI SEL: Pure White, DSG
capt_slow is offline   Reply With Quote
Old June 17th, 2020, 07:43   #1047
mjez
TDI(s): 00 Jetta
Fuel Economy: 47mpg
Has anyone here changed their transmission fluid in the ZF 8 speed?
I got fluid from Northside Imports the other day and guy gave me fluid for ZF 9 speed saying that they received memo from BMW saying that this is correct fluid for BMW diesel vehicles and said something about lawsuit they lost after selling one customer fluid for 8 speed and his transmission failing shortly after he changed it. Has anyone heard anything like that? I searched on ZF website and they show 8 speed fluid as the correct type.
For those that are planning on changing transmission fluid in their BMWs.
I contacted ZF in regards to what fluid should be used in ZF HP8 transmission and was told that both, ZF8 as well as ZF9 fluids are perfectly fine to use and mix in those transmissions.
Old June 17th, 2020, 11:30   #1048
tomo366
tomo366's Avatar
Check ID Parts he has the kit
https://www.idparts.com/automatic-tr...01-p-5743.html
Old June 17th, 2020, 22:03   #1049
3turboz
3turboz's Avatar
Originally Posted by capt_slow View Post
.........For those that like to wrench on their own cars, ISTA and newTIS are essential.......
Great info, What is the best place to buy ISTA? I see a download on ebay or from bimmerdiagnostics.com. Are they both legit? Looks like they are both out of the UK.
Old June 18th, 2020, 13:11   #1050
mjez
TDI(s): 00 Jetta
Fuel Economy: 47mpg
Look for a download link, I had a friend send me one but no longer have it. Then get a cable, I got one from either eBay or Amazon. It's a pain to set it up first time but there are plenty of videos and articles on how to do it. It is a great tool to have, saves time and money as well.
TDIClub Secret Society of Benz Owners (SSBO) cevans Non VW Group Diesels 622 September 4th, 2018 16:41
BMW 335d owners Capt. Common Rail Non VW Group Diesels 38 January 8th, 2017 19:59
--::Polo Cult Society::-- Mosdef Other TDI/Diesel Picture Gallery 0 November 14th, 2002 11:12
Any BMW owners around here? D-Dawg Non VW Group Diesels 8 January 20th, 2001 09:13
Any BMW 525tds owners out there? dave525tds Non VW Group Diesels 6 April 4th, 2000 02:40
Page generated in 0.18415 seconds with 11 queries
[Output: 134.96 Kb. compressed to 113.07 Kb. by saving 21.89 Kb. (16.22%)]
