Old November 3rd, 2013, 02:20   #1
noxneon
Default request for big mileage on big torque motors.
Is there anyone out there that has big mileage on a big torque motor ? I'm trying to focus on the 300-400 ft lb of tq range. Also the 200-300 range for a stock bottom end. Bonus points if that bottom end never comes out of the car. I'm serious here guys. When I talk about the work my Jetta can do, stock, at over 231k miles, trans clutch and turbo included, its unbelievable. So I want to take this a step further. The video that was posted in my thread about diesels doing hard work, the one with the old school bug and the roof hitch, has really got me thinking. I need to make my way up to Vancouver, BC and get one of the deals I've seen on TDI mk4 wagons. I already even have the diesel truck I could use to tow it back. I think the wagon would be the ideal setup, because its got the greatest surface area on the roof to spread the force of whatever load would be connected. I basically am trying to "copy" the dyno graph of my diesel truck, but with the motor in my diesel car.
noxneon is offline   Reply With Quote
Old November 3rd, 2013, 08:21   #2
BlankThis
BlankThis's Avatar
Fuel Economy: suck, squeeze, bang, smoke
Those are pretty high numbers, but are completely doable if you throw enough money at it. Then again, I don't know how the transmission will like that.
Just off the top of my head...
Turbo (17/22 VNT)
Front mount intercooler
PD150/custom intake
3" downpipe + exhaust
11mm pump + lift pump
Race 520s
Head studs
Cam
Monster clutch + LSD (if you're smart)
Port & polish?
Motormounts (stockies would probably get torn right off the first pull)
For the price of all those parts without labor you could probably pick up a pretty clean F350 Diesel or similar.
[360k] - | GT1749VB | DLC764s | Southbend Stage 3 daily (soon) | WIX 24770 + CAT 1R7050 | DG Sigma 5 | 25th anni. e-codes | W8 console | NewSouth boost gauge | Koni Yellows/SRT.Ts w/ Neuspeed Sport springs | 1.8T pancake (soon) | PD150 intake w/ racepipe (soon) |
BlankThis is offline   Reply With Quote
Old November 3rd, 2013, 08:51   #3
vanbcguy
vanbcguy's Avatar
I sure haven't seen many deals on TDI wagons around here!
The only ones that ever seem to pop up under $10k are salvage title or thrashed.
You definitely can build a TDI that will get in to that power range no problem but yeah, it isn't going to be cheap. I'm working on one right now, my build budget has almost matched what we paid for my wife's '04 1.8T wagon back in the spring. I'm going all out though....
My build thread: http://www.vwdiesel.net/forum/index.php?topic=32967.0
vanbcguy is offline   Reply With Quote
Old November 3rd, 2013, 11:42   #4
mk1-83
Fuel Economy: 1:15
Dump that 17/22 go with a gtb 2260 and 12mm with race520
Lupo 1.9 tdi
H-beam, 1:17 cr, 12mm pump,dss-r.360,gtb2365 vklr.
300+ HP 500 nm
https://www.youtube.com/watch?v=1h3bxhWZcvk
mk1-83 is offline   Reply With Quote
Old November 3rd, 2013, 14:32   #5
mrchill
Super Secret Diesel Ninja Vendor
w/Business #
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
I think he wants mileage too...so a big turbo is out.
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old November 3rd, 2013, 16:16   #6
loudspl
loudspl's Avatar
TDI(s): 02 ASV
Fuel Economy: lolz
If you want to pull stumps with big TQ at low rpm, stick to a 49mm turbo
GTC1549vz is the cat's meow right now.
http://www.ebay.com/itm/Audi-A4-A5-A...item35c29db2ac
http://www.shop.ngc-turbotechnik.de/...-vw-gruppe.php
I would go for that or a 3rd gen 49mm VNT way before a 1752 or 2260
400ft-lbs and 200bhp shouldn't be a problem. Go easy on driver's request (except when pulling stumps) and FE should be 40+MPG too
02 Jetta, 17:1 CR 81mm ASV, Colt cam, Peloquin LSD, Raxles, FueLab pump, 12mm/DE143, Gibonta 5 x 0.018, NX nitrous, 6+6 turbo, Bilstein coilovers
MKVII GTI 6MT, full build, 525hp
MKVII GLI DQ381, 93 tune only, daily driver
loudspl is offline   Reply With Quote
Old November 3rd, 2013, 17:03   #7
A5INKY
Fuel Economy: pretty good
GTC1549vz is the cat's meow right now...
Can't agree more!
Like this one: http://www.ebay.com/itm/300967161647...84.m1555.l2649
A5INKY is offline   Reply With Quote
Old November 3rd, 2013, 19:17   #8
john.jackson9213
TDI(s): 1996 B4V
Here are two builds I have personally seen run on the dyno:
http://forums.tdiclub.com/showpost.p...01&postcount=1
http://forums.tdiclub.com/showthread.php?t=312340
I have driven to Las Vegas with Jeremy in his car. Got 37/38 mpg on that trip and the road to Vegas is not a slow freeway. You do 70, and you are getting passed at 80-85 That was with 380 lb/ft of torque
JJ
1996 B4V, Hella E-Codes, GLX leather, EuroTuning.cz 02A 6 speed conversion w/.71 5th and .588 6th gear, A4 shift linkage by Matt-98AHU. 11 mm pump by Oldpoopie. Now, GTC1549VZ turbo by Whitbread. TDtuning, 24 lbs. boost, 162 hp, 285 lb/ft tq. Smoke Free (9/18/15). Koni Yellows and Big Brake 5 lug conversion.
john.jackson9213 is offline   Reply With Quote
Old November 4th, 2013, 03:42   #9
noxneon
Vancbcguy: you guys seem to have all the good deals compared to my area.
The plan was to find a mkiv wagon that had a bad engine and or trans to do the build on. Or find a good running higher mileage car ... but I already have a diesel f250. The thing is it will never reach 20 mpg... ever. Straight drive c6 ford bb auto trans, 6.5k lbs dry weight and 4wd get me about 19 mpg, and that's way down at like 55 mph. I don't actually think I'll even need more then 225-250 lb ft of torque. I'm just trying to mimic the trucks dyno curves as much as possible.
Old November 4th, 2013, 07:02   #10
drewkeen
TDI(s): Jetta
Your truck was rated at 180hp and 345 ft/lb at the crank (or less if you have a 6.9)
It is also routed through an auto trans and 4x4 stuff for more power loss. At a conservative 15% loss you would put down around 153hp and 293 ft/lb. Should be fairly easily attainable with a TDI.
drewkeen is offline   Reply With Quote
Old November 4th, 2013, 09:22   #11
noxneon
yeah my truck is the 6.9. 175 hp, 315 lb ft of torque. but i get my torque at 1400 rpms. but it has never not towed what we put behind it.
Old November 4th, 2013, 09:32   #12
A5INKY
Not going to get your torque peak nearly that low with a little 4 cylinder. Faster turbo spool at a lower RPM will help burn the fuel it takes to build a bigger earlier torque peak. But at some point it also becomes a simple matter of displacement, 1.9L is a whole lot less than 6.9L.
Old November 5th, 2013, 00:18   #13
Alcaid
Alcaid's Avatar
I agree with the suggestion above: GTC1549VZ all the way!
I've done a day of driving at 61.8MPG with my '10 Passat running a GTC1244VZ
'03 VW Golf PD130 4Motion Highline - GTB2056VL, 4 bar map, FMIC - 191whp/320wft-lbs @ 4x4 Dynapack
'10 VW Passat 1.6TDI Highline - 2.5" DP (DPF/Cat delete), DP built and software by VVT - 145bhp/229ft-lbs
'83 VW Jetta 1.6TTD - Holset HE200WG-5cm + Custom Holset HX30W-12cm compound, 12mm Dieselmeken pump, Rosten rods, girdle, Ported AAZ head with custom valves, valve springs, Ti retainers, camshaft +++ WIP
Alcaid is offline   Reply With Quote
Old November 5th, 2013, 03:05   #14
Digital Corpus
Digital Corpus's Avatar
I'm waiting to see a dyno of the GTC1549vz. I see a lot of talk but not much in hard numbers.
Turbo Upgrade | Engine Rebuild | Photos | Lighting Mods
Dyno Graphs | 4-Bar sensor | GTB1756VK | Hot-swappable 2.5" down pipe | R520's | PD130 intake manifold
Digital Corpus is offline   Reply With Quote
Old November 5th, 2013, 04:57   #15
Alcaid
Alcaid's Avatar
No dyno plots yet, but TDIMeister has shared some numbers on it:
Originally Posted by TDIMeister View Post
I know of someone who just purchased a GTC1549VZ, P/N 03L 145 721B, fitted into the CR170. I believe this will be the hot turbo for people who want a moderate performance upgrade -- supports max PR=3.4 and 0.18 kg/sec (24 lb/min) -- without sacrificing one-iota of spool-up response from stock, if not even better. Will keep updated.
24lbs/min should do 200-215 smoke free bhp and PR is very impressive on these new generation comp wheels vs. the small comp exducer sizes!
again. request for guys with mileage on big torque motors... noxneon Upgrades (non TDI Engine related) 0 November 3rd, 2013 02:19
IDParts Exclusive TDIFest Specials! Big Discounts on Big Stuff! cevans TDIFest 2013 18 August 29th, 2013 10:28
Jeep, VW Roll Out Big Diesels in the Big Apple dieseldorf Non VW Group Diesels 7 April 22nd, 2007 10:28
BP gets big lift from big oil prices, Profits Rise PDJetta Fuels & Lubricants 1 October 25th, 2005 21:57
Big Injectors: MPG and hp and torque BillsVW TDI Power Enhancements 2 April 9th, 2001 21:05
Page generated in 0.15759 seconds with 11 queries
[Output: 131.91 Kb. compressed to 110.22 Kb. by saving 21.69 Kb. (16.44%)]
