Old December 3rd, 2012, 20:36   #1
AARodriguez Corp.
AARodriguez Corp.'s Avatar
Default VCDS No response from Contoller, but SnapOn code reader works
A customer has a 99.5 TDI golf, we were unable to scan his car using VCDS with his original ECU, a tuned ECU was installed and we are still unable to scan the car with VCDS, the only message we get is, "No response from controller"
The only time I've seen this happen before was with a bad cluster.
Any thoughts?
AARodriguez Corp. is offline   Reply With Quote
Old December 4th, 2012, 08:59   #2
jef@rosstech
Associate Ross-Tech Vendor
When you plug the interface up to the OBDII port of the car, what does the LED light do?
Start VCDS, what version are you running?
Click on [Options], then [Test], what are ALL of the results of the Port Test while connected to this vehicle?
Just so everyone knows, all of our registered users can call us for free product support if they are having communication issues.
Jef blah blah blah
www.Ross-Tech.com
What should you do first with VCDS? AUTOSCAN!
jef@rosstech is offline   Reply With Quote
Old December 4th, 2012, 09:02   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
The Snap On most likely is just accessing the generic [useless] OBD2 side of things, which goes straight into the watered down part of the engine controller, not through the K-line like the native VAG version (and VCDS) would use.
The K-line would go through the Instrument cluster, correct. Check all the fuses first, though.
oilhammer
www.cardocautomotive.com
Old December 4th, 2012, 10:57   #4
Ol'Rattler
Ol'Rattler's Avatar
The aftermarket radio problem? Or would the Snap-On tool not work either?
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old December 4th, 2012, 15:14   #5
Lone Ranger
TDI(s): TDI Ranger
Odd, and almost the opposite of what my truck does. (2002 ALH in a Ranger) My VCDS connects and works flawlessly, but I tried to add one of those digital gauge units(scangauge II) and it won't connect.
Lone Ranger is offline   Reply With Quote
Old December 13th, 2012, 11:13   #6
cheeze you
Fuel Economy: 35-40
Led turns green.
Version 11.11
Test yields such:
Port status: ok
USB library version: 03.01.19
USB driver version: 02.06.01
Interface: Found!
Type: Ross-Tech HEX-USB+CAN
Version: 1.92
Status: questionable.
K1: short to +12
K2: OK
Can: not ready.
Just got off the phone with Ross-Tech guy on the phone said I need to be subscribed to your phone support and also since I don't own the VCDS cable and it is a loan from a friend he couldn't help me.
Thanks,
-Scott.
cheeze you is offline   Reply With Quote
Old December 13th, 2012, 11:16   #7
cheeze you
Fuel Economy: 35-40
Attempted to pull fuse 11(cluster fuse) didn't change anything.
Thanks,
-Scott.
Old December 13th, 2012, 11:16   #8
cheeze you
Fuel Economy: 35-40
I have an aftermarket radio. Snap-on will read VCDS won't read.
Old December 13th, 2012, 11:17   #9
cheeze you
Fuel Economy: 35-40
2002 ALH in a Ranger? Best of both worlds. I have a 2000 ranger that just rolled over 200k never had any problems with it.
Old December 13th, 2012, 11:24   #10
jef@rosstech
Originally Posted by cheeze you View Post
K1: short to +12
There is the issue, is should read K1: OK. Most of the time this is due to an aftermarket radio (as noted above). We have more information on this on our web site:
http://www.ross-tech.com/vag-com/aftermarket-radio.html
The short version... is terminal #3 of the black power plug on connected to the aftermarket radio wiring harness? If so, cut the wire on the aftermarket radio harness and tape it off.
Just to clarify, registered Ross Tech customers can contact Ross Tech directly for support. If a Ross Tech customer loans his interface to a friend, that is fine, but said friend is not a Ross Tech customers and does not qualify for support directly from Ross Tech (phone or email).
Registered users can get free product support directly from Ross Tech over the phone. Product support is to help our customers to get the software and hardware up and running so they can communicate with a vehicle (this OP's issue here would fall under product support). Anything beyond that is vehicle support, which is a fee based service over the phone. Ross Tech still has free support for our customers via email.
Questions on forums like this, we don't mind helping out some one who is borrowing an interface from one of our customers. We hope that people will see the value in being a Ross Tech customer (in terms of support and the product itself) and make the small investment to purchase the best tool on the market. [/small sales pitch off]
Jef blah blah blah
www.Ross-Tech.com
Old December 13th, 2012, 11:57   #11
cheeze you
Fuel Economy: 35-40
Awesome, worked just like you said.
Now I've gotta adjust the IQ level.
Old December 14th, 2012, 09:29   #12
Ol'Rattler
Ol'Rattler's Avatar
For a real treat, call Dell's or Micro$oft's customer support. Not even close to the excellent support RossTech provides.
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old December 15th, 2012, 13:34   #13
AARodriguez Corp.
Jeff thank you very much for helping my customer, really appreciate it!
Old December 15th, 2012, 18:20   #14
csstevej
+++1 to Jeff for his product and support.
2001 golf auto to 5 speed manual swap,G60/VR6 clutch setup,coolant migration mod.
csstevej is offline   Reply With Quote
Radio unit SD/MMC card reader: works fast? pierreracine VW MKVI-A6 Jetta Sedan (~ 2011+) 2 June 6th, 2011 16:46
No response from Contoller when engine is warm grenjs TDI Conversions 13 May 4th, 2010 12:37
Code Reader blackmagic16 Atlantic Canada 0 April 20th, 2009 09:37
fault code P0743 and Snapon codes 00300 and 00264 nsadoc TDI 101 3 November 23rd, 2008 07:32
Vag com code 00527 - code reader P1161 tdidieselbobny TDI 101 4 December 11th, 2006 13:07
Page generated in 0.18676 seconds with 11 queries
[Output: 127.91 Kb. compressed to 107.70 Kb. by saving 20.21 Kb. (15.80%)]
