Old October 26th, 2012, 08:26   #1
ExtremeMachine476
Default What oil to refill 6MT in 2010 VW Golf TDI
Hey guys,
Looking to change oil in my 6 speed manual transmission. I know the manual states that no service is required, but i'm doing it anyways. I'm planning on running the off the shelf OEM fluid from the dealer. Is there any oil superior to the OEM, that you have tried and yielded good results? Where I live we can see varying temps from -20 degrees celsius to hot humid days in the summer.
Nick M
ExtremeMachine476 is offline   Reply With Quote
Old October 26th, 2012, 08:34   #2
nikhsub1
TDI(s): 2015 Golf R
I would go with whatever OEM is... no need to reinvent the wheel. VW typically uses high quality lubricants.
2015 Golf R
nikhsub1 is offline   Reply With Quote
Old October 26th, 2012, 08:35   #3
whitedog
How many miles on this car?
Old October 26th, 2012, 08:36   #4
ExtremeMachine476
50 000 km
Old October 26th, 2012, 09:09   #5
whitedog
MAYbe think about it at 150,000km, but to change the oil now is - quite frankly - a waste of time and money.
Old October 26th, 2012, 09:24   #6
T_D_I_POWER
T_D_I_POWER's Avatar
Originally Posted by ExtremeMachine476 View Post
Hey guys,
....... I'm planning on running the off the shelf OEM fluid from the dealer. Thanks
Nick M
Off the shelf fluid from the dealer is called the OE fluid Part Number: G052171A2
Any off the shelf parts from the dealer are OE Parts.
OEM motor & transmission fluid would be Pennzoil, Mobil 1, Castrol, Motul, Penntosin etc.
//TDI POWER
2004 B5.5S
1st TO USE Mobil 1 ESP Formula M 5W-40 IN THE CLUB http://forums.tdiclub.com/showpost.p...56&postcount=9
1st TO PREFILL OFH/OFI INSTL W/ OIL IN THE CLUB http://forums.tdiclub.com/showpost.p...02&postcount=5
1st TO PREFIL FF W/ DIESEL FUEL IN THE CLUB http://forums.tdiclub.com/showpost.p...4&postcount=14
T_D_I_POWER is offline   Reply With Quote
Old October 26th, 2012, 09:27   #7
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
You sure about this? I thought the new OEM fluid was G70 and G52 has been superseded.
-tom
autos: 19 Subaru Forester, 14 BMW 535d xDrive
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old October 26th, 2012, 10:20   #8
2micron
TDI(s): None
Hello fello Canadian! Stick to OE or direct replacement oil for your Gearbox.
Our oil has to be GL4.
GL5 will degrade and slowly destroy your bronze syncros.
Here is an old thread, and magnetic drain plug information.Hope it helps you!
http://forums.tdiclub.com/showthread...20#post3812120.
All the best,
2micron is offline   Reply With Quote
Old October 26th, 2012, 11:09   #9
CalAltaDubber
CalAltaDubber's Avatar
Fuel Economy: 6.1 l/100km
You can't go wrong with off the shelf oil the OEM uses.
If you have the VW spec for the oil, you can safely use any oil that meets that spec.
Phil
CalAltaDubber is offline   Reply With Quote
Old October 26th, 2012, 13:07   #10
Rauss
Rauss's Avatar
Fuel Economy: Worst 38mpg \ Best 52mpg
507.00 Oil Like Castrol, Gulf, Synto etc...
.:Rauss
Rauss is offline   Reply With Quote
Old October 26th, 2012, 13:09   #11
tditom
That works fine for the engine, but isn't intended for the transmission...
-tom
Old October 26th, 2012, 17:52   #12
IFRCFI
IFRCFI's Avatar
http://www.amsoil.com/catalog.aspx?code=MTGQT-EA
Sent from my iPad using Tapatalk
IFRCFI is offline   Reply With Quote
Old October 26th, 2012, 18:26   #13
For the 5 speed yes. Not for the 6-speed. G052171A2 is the correct fluid. Takes 3 liters. Quite a bit more expensive than the G070, too. I wouldn't change it until 160K kilometers.
2002 Jetta wagon, 412K, RC3+; 1993 Mercedes-Benz 300D 2.5, 199K; 1997 Passat, 289K; '99.5 Golf, 262K; 2011 335d, 64K; 2015 Golf Sportwagen, 14K. Principal, http://www.idparts.com
Old October 26th, 2012, 19:17   #14
bhutchins
bhutchins's Avatar
Fuel Economy: best 47
your 02Q (2010 6spd manual) takes G052171A2 $28.95/L
Sold : 234 WHP / 404 WTQ (550 N-M)
bhutchins is offline   Reply With Quote
Old October 26th, 2012, 19:50   #15
ExtremeMachine476
Thanks 2micron for your write up! Was so good I even ordered the drain plugs.
FS: 2010 Golf TDI 6MT 4 door $20,000 - Maryland NicholasJay TDI Cars for Sale/Wanted 0 May 10th, 2012 16:44
2010 VW Golf TDI, Graphite Blue, 6MT, 4-door, San Antonio, TX trailer_parks TDI Cars for Sale/Wanted 5 December 18th, 2011 16:32
FS: 2010 Golf TDI 4 door (6MT) in NJ honda93 TDI Cars for Sale/Wanted 0 May 5th, 2011 18:23
Weird delayed start - 2010 Golf TDI 6MT soldierguy VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 5 January 4th, 2011 11:20
2010 Golf TDI (6MT) > Popping out of 6th gear! honda93 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 7 November 4th, 2010 21:49
© 1996 - 2020, All Rights Reserved
Page generated in 0.16162 seconds with 11 queries
[Output: 127.53 Kb. compressed to 106.25 Kb. by saving 21.28 Kb. (16.69%)]
