Old October 11th, 2012, 20:56   #1
surfbus
surfbus's Avatar
Default Clutch master cylinder and Slave clutch cylinder repair kit?
1996 B4 TDI: I want to rebuild my clutch master cylinder. Where can I buy seals for this? And also for the clutch slave cylinder seals as well... both are only sold as a complete new unit the places I've looked. Please advise, thanks!
Door handles 139$, headliner 500$. No camshaft, balance shaft or high pressure fuel pump issues to repair... priceless!
surfbus is offline   Reply With Quote
Old October 13th, 2012, 10:07   #2
surfbus
surfbus's Avatar
Anyone know? Am I stuck with buying a new unit at $100+ ???
Old October 13th, 2012, 20:35   #3
Volk14
I have never heard of anyone selling the seals to re-build the clutch master cylinder and slave cylinder.
The new parts might be a little expensive but they do last a long time, just make sure that you get good quality parts. It's a pain to replace the master cylinder and a bad/defective slave cylinder can kill your clutch.
Just my $0.02
Volk14 is offline   Reply With Quote
Old October 19th, 2012, 22:39   #4
nursewithawrench
TDI(s): mk3 98 Jetta
Default Improv
I knew a guy with this same problem and he just would not keep his foot on the clutch at stoplights and if he kept it in to the point it would stay down, he would just pull his toe under it and pull it up. Dont get stuck in gear when this happens though; the car in front of you wont be very forgiving.
My very first post!
Which are shot? master, slave or both?
nursewithawrench is offline   Reply With Quote
Clutch master cylinder or Slave cylinder, Which is FAIL ? Mcgink VW MKIII-A3/B4 TDIs 22 November 26th, 2014 13:34
Clutch master or slave cylinder issue? gforce1108 VW MKIV-A4 TDIs (VE and PD) 19 August 13th, 2014 13:34
Clutch master and slave cylinder failure milktree VW MKIV-A4 TDIs (VE and PD) 1 September 28th, 2012 13:41
Bad clutch slave or master cylinder? GTSLOW VW MKIII-A3/B4 TDIs 26 September 26th, 2012 07:33
Clutch master and slave cylinder ky_tdi_mike VW MKIII-A3/B4 TDIs 21 May 16th, 2007 14:40
Page generated in 0.12534 seconds with 11 queries
[Output: 63.44 Kb. compressed to 56.82 Kb. by saving 6.63 Kb. (10.45%)]
