Thanks for you answer sir and I will not be doing it. I did let VW know it was strange at least one port wasnt left on.No, however you could modify the fuse/ safety part (forgot its name) to constantly supply power, however i would worry about doing this because:
(sorted by danger level as follows)
A. what if a coin or something similar were to fall into it- it might(however-unlikely...) Fry something VERY expensive in the Central Electronics Control Module instead of just blowing a fuse!
C. if you did this and a dealer CAUGHT you... kiss your warranty's a** goodbye
B. it could allow a vampire load to kill your battery if you were to forget to unplug something(oops)
D. taking the tiny thing apart is also a ROYAL PITA!
Conclusion: so ask yourself is the 5-30 minutes of work really worth all the risks for such a tiny gain... it is your car NOT mine so think about what you are doing some before you do this mod...
Learning about TDI's.
