Old September 21st, 2011, 08:05   #1
AndyBees
AndyBees's Avatar
Default ScanGauge and VCDS question
This is off topic ............ if need be, moderator, please remove.
A good friend of mine purchased a new KIA Optamia in 2003. I begged him to consider a Jetta TDI.
Anyway, after I repaired his most recent problem (new fuel pump at 276k miles), I tried to clear the codes with ScanGauge. When I punch YES to delete the codes, the screen goes BLANK. I tried numerous times to delete the codes to clear the Check Engine Light. The Codes P1166 & P1167 are Ox Sensor related due to the leaning of fuel because of the failing fuel pump............he drove it until it quit, even with several weeks of warning signs.
Also, VCDS will do some basics with the KIA, but I also could not clear the codes with it. The message was that the Codes may not have been removed. The tests with VCDS said that the Ox Sensors passed okay, as well as all other systems in the test sequence.
Any ideas what he needs to do besides a costly trip to the Dealership?
This is the TDI Club, a place to share experiences & ideas, ask for help, etc. Welcome Newbies! Sarcastic and condescending posts shouldn't be welcome.
Question for Scangauge owners DustyB TDI 101 6 August 4th, 2011 09:56
VCDS or Not to VCDS, THAT IS THE QUESTION BRADFORDKO TDI 101 6 July 15th, 2011 21:21
SCANGAUGE question TurboABA Ontario 8 December 7th, 2010 07:00
Question about scangauge with larger nozzles robhegedus OBD Scanners 4 January 22nd, 2010 06:23
Scangauge Calibration Question Silver02TDI Ontario 6 February 22nd, 2008 08:46
Page generated in 0.10024 seconds with 11 queries
[Output: 48.67 Kb. compressed to 45.62 Kb. by saving 3.05 Kb. (6.27%)]
