Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old January 8th, 2019, 07:07   #601
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
Originally Posted by fairbanks View Post
My car is a 2005 Passat, 2.0 TDI
I have become very intimate with her, I have stripped her down several times, and when I'm done she still responds the same way, Emissions workshop!
I have replaced the fuel\vacuum pump
Turbo, the mass air flap,the inter cooler hose from turbo, the silver domed vacuum reservoir, all vacuum lines, the cylinder head, I have cleaner the air sensor just before the engine, and changed the oil, and even gave her a kiss.
How do I clear this Emissions workshop?
The head was the problem, two valve failures, with the new head it starts up right away, not even one turn, I have the OBDeleven, that can clear codes but how can I clear the Emissions Workshop?
You've probably not received any help in this thread since it doesn't apply to your car/engine. This thread only relates to the specific emissions issues of the 2009 common rail diesels and newer.
2010 silver/black JSW TDI with DSG, 2017 Ram 1500 EcoDiesel
kjclow is offline   Reply With Quote
Old May 12th, 2019, 14:37   #602
Bio
So I still have my 2012 tdi Passat, while I was driving back to school, it caught on fire, had the car towed to a VW dealership and this is what they found. They found a hole underneath the DPF, they are sending two engineers, one from Chattanooga and another one from Germany to determine the cause of this melt down and liability. From what they can tell so far, so much soots were in there and it got so hot, it melted a hole. Not sure how to load pictures on this yet, but will keep you all updated.
Bio is offline   Reply With Quote
Old May 29th, 2019, 09:42   #603
Clawdog60
Whats with all of the oil on the bottom of the motor?
I assume thats what was on fire from the exhaust/catalyst.
Clawdog60 is offline   Reply With Quote
Old May 29th, 2019, 12:17   #604
Bio
Honestly, I have no idea, now they are saying there is no sign of fire damage. Literally trying to evade responsibilities. Will have to try them again . Will keep you guys posted. This has been a nightmare.
Old October 8th, 2019, 21:23   #605
capt_slow
capt_slow's Avatar
MemberName: capt_slow
Model Year:
2015
Model:
GSW
Tranny:
DSG
Miles:
21900
Oil Ash Volume:
10ml
Oil Type:
G-052-195-1Q-DSP(Castrol LL03)
Avrg. MPG:
35.59
Comments:
IDE00420 Service regeneration: current duration 0.00 s
IDE00432 Particle filter: time since last regeneration 3227 s
IDE00433 Particle filter: oil ash volume 0.01 l
IDE00434 Particle filter: soot mass calculated 11.41 g
IDE00435 Particle filter: soot mass measured 3.34 g
IDE00436 Particle filter: kilometers since last regeneration 75025 m
IDE04272 Counter for regeneration time of diesel particle filter 0.00 s
IDE06059 Particulate filter: oil ash mass 4.6 g
IDE06060 Particulate filter ash load limit 80.00 g
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, Driver Assist Pkg, M-Sport Pkg, Premium Pkg, ACC, Side/Top Cameras, Park Assist, Nav, HK
2015 GSW TDI SEL: Pure White, DSG
capt_slow is offline   Reply With Quote
Old October 15th, 2019, 14:37   #606
jerrymander
jerrymander's Avatar
Welcome to Volkswagen Auto Group. Enjoy the ride.
jerrymander is offline   Reply With Quote
Old January 4th, 2020, 07:35   #607
pep254
TDI(s): A3 Jettas
A good solution to clean DPF https://mr-c.site
pep254 is offline   Reply With Quote
Long-term DPF data project DoctorDawg VW MKV-A5 Golf/Jettas 55 January 30th, 2013 16:42
Off-topic posts from Cam Failure Data Collection thread donDavide Fuels & Lubricants 63 June 14th, 2011 23:18
PD cam failure - Data collection thread SBAtdijetta Fuels & Lubricants 116 February 25th, 2011 21:21
Biodiesel in DPF/Clean diesel vehicles Drivbiwire Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 6 August 25th, 2010 08:55
2009 Jetta Clean Diesel w DPF = Regen? Rod Bearing TDI (Diesel) Emissions 5 October 15th, 2008 18:58
Page generated in 0.17209 seconds with 11 queries
[Output: 85.20 Kb. compressed to 74.53 Kb. by saving 10.67 Kb. (12.52%)]
