Old March 31st, 2011, 20:04   #1
pigpenracing
TDI(s): golf jetta
Default no fans and no ac need to test compressor
I just bought a 2000 Golf. The cooling fans and ac compressor are both dead. I bought a new fan control module off ebay and had no luck. There are two wires on the AC compressor, which is hot and which is ground? I want to hook power to it for a second just to make sure the compressor does kick on. Anything else to look for? I pulled the fuses on top of the battery and sanded the contacts, still no luck.
pigpenracing is offline   Reply With Quote
Old April 1st, 2011, 05:22   #2
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
Since it's just a coil, I don't think it'll really matter which way you hook power to it. Ohm it out first to see if it has continuity. This thread should have everything you need:
http://forums.tdiclub.com/showthread...ight=check+fan
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is offline   Reply With Quote
Old April 1st, 2011, 06:17   #3
hevster1
TDI(s): 98 NB
Fuel Economy: 40-42
First, engine off, try to turn the inside part of the clutch by hand. If it doesn't turn the compressor is seized.
Attach gauges. Do you have at least 50-60 PSI on both the high and low side? If not add some refrigerant and see if it begins working.
Disconnect the connector and connect a DVOM. Have an assistant start the car and turn A/C to on. Do you have battery voltage? If so you have a clutch issue. If not it could be wiring or a bad switch/relay. If you have low voltage, it usually indicates corrosion at a connector. Time to hit the manual or bring to a professional.
Resistance checks are often inconclusive on A/C clutches.
NJ's best shop performing Quality Repairs on TDI's, Toyota, Lexus, Scion and other European and Asian cars as well as Motorcycles & ATV's. Written warranty, reasonable prices. ASE L-1 & A-9 Master re-certified. NEW LOCATION: Montague NJ. Hunter Wheel Alignment. Snap-on Tire Service.I don't need to have specials, my prices are better already!
www.mmautocycle.com
hevster1 is offline   Reply With Quote
Old April 1st, 2011, 06:25   #4
gquenstedt
If the pressure switch is bad, neither the fans or the compressor will come on, when you turn on the AC. There is a test for the pressure switch that DanG144 explains in his A/c troubleshooting guide. Whatever you do, do not try shorting it with a jumper wire, that will fry your computer.
I highly recommend not buying fan control modules or pressure sensors from ebay. I have seen them cause major headaches.
Check out my website: www.gqlaw.us
gquenstedt is offline   Reply With Quote
A/C Compressor and Radiator Fans Inoperable skibby TDI 101 0 May 20th, 2010 19:03
AC warm air, but compressor and fans DO run mk3 VW MKIV-A4 TDIs (VE and PD) 38 July 31st, 2009 10:20
WTB MkIV AC Compressor clutch or trashed ac compressor (with good clutch) Ironforger Private TDI Items for Sale/Wanted 0 December 1st, 2007 17:24
FS AC compressor...other AC parts free orion2.0 Private TDI Items for Sale/Wanted 1 November 10th, 2007 12:57
use AC compressor as a AC vacuum pump redtdi966 VW MKIII-A3/B4 TDIs 5 July 18th, 2007 18:00
Page generated in 0.12524 seconds with 11 queries
[Output: 64.92 Kb. compressed to 58.25 Kb. by saving 6.67 Kb. (10.27%)]
