Old January 15th, 2010, 18:12   #1
cr9c1
Default 98 Jetta TDI clutch slave/master cylinder / shifting problems
Hi guys. I've searched to no avail. The clutch is not disengaging. Sounded to me like the slave cylinder wasn't holding its pressure so I ordered a new one, installed, and bled it. No change.
You have to "bump" the accelerator to spin the syncrhos up to shift it, because the clutch isn't disengaing all the way. Its hard to shift period. Any other options other than replacing the clutch at this point that might be the culprit? I know nothing about how these clutches work in these cars at all.(The hydraulic part)
It was working fine and then all of the sudden this just happened. It hasn't been progressive, which leads me to believe something else may be at fault. Perhaps adjustment or something? But I have no idea if it has an adjustment or how to get to it / where it is etc. Any help is greatly appreciated.
cr9c1 is offline   Reply With Quote
Old January 16th, 2010, 04:51   #2
DieselFahrer
Default re : clutch won't disengage :
You didn't mention how many miles are on the current clutch, but
given the year of the car perhaps the clutch has a lot of miles on
it, and some clutch parts have fatigued and failed.
I think it's possible ( likely ! ) that some sort of debris is preventing the
clutch friction disc from having little or no pressure on the
flywheel face when the clutch pedal is depressed fully.
It's known that the coil springs incorporated in the clutch friction
disc can break, and when the springs break sometimes pieces
of the spring become lodged in the clutch and cause the clutch to
fail to release fully. It only takes a small amount of drag to make
it impossible to shift into first gear from neutral with the car at
a standstill. Once the car is moving, shifting may be possible but
careful timing might be required to avoid grinding gears.
Here's something you can try, and it may not help but I've seen
it work before. NOTE : this is NOT a long-term solution, but it might
buy you some time until you can replace the clutch.
First, buy at least two cans of Brakleen or equivalent spray-can
brake cleaner. If possible, plan to have a person available to
help you during the steps below.
1) set the parking brake in your car.
1) a) remove the rubber "timing hole" plug ( found on the transmission bell
housing near the clutch slave cylinder ).
2) start the engine and let it idle.
3) attach the small spray tube to the spray nozzle of the brake cleaner
and carefully insert the spray tube into the timing hole which was
exposed when you removed the timing cover. NOTE : make sure the
spray tube is FIRMLY attached to the spray nozzle. You do not want the
spray tube to fall into the hole.
3) a) Spray lots of brake cleaner into the timing hole, with the engine
running ( the idea is to hose down the clutch and flywheel with brake cleaner ) and if you have a helper, get him/her to repeatedly press the
clutch pedal in while you spray the brake cleaner.
NOTE : AT NO TIME SHOULD YOU INSERT ANY PARTS OF YOUR HAND
OR ANY TOOL INTO THE TIMING HOLE. Ok, this *should* be obvious,
but serious injury is possible so a warning was in order.
The idea is to loosen the crud which might be holding the broken
pieces of friction plate or its spring in place, such that the pieces of
spring will be ejected and the clutch will then release.
It's likely a puddle of brake cleaner mixed with "crud" will appear under the car where the engine and transmission mate, so you might want to put
something ( towels, newspaper ) under that area to catch the spill.
Again, remember that you probably need a new clutch, and this is not going to change that, but it might buy you some time.
DieselFahrer is offline   Reply With Quote
Old January 16th, 2010, 05:18   #3
White Crow
TDI(s): 2002 gls tdi
Fuel Economy: 52 all around driving (some city mostly open road
DMF coming unglued?
White Crow is offline   Reply With Quote
Old January 16th, 2010, 09:28   #4
TonyJetta
Fuel Economy: A5: 36mpg Avg / A6: 39
Originally Posted by White Crow
DMF coming unglued?
Not likely. '98 and earlier is a simgle mass flywheel.
My vote would be to replace the clutch master cylinder. If that doesn't work, then replace the clutch assy.
Tony
Diesel fleet: '15 Jetta TDI SE; '06 Jetta, TDI, DSG-5sp Conversion; '06 DC Cummins, CC/LB/DRW; Past Project car! Troubleshooting Links: Trusted TDI Mechanics IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is offline   Reply With Quote
Old January 16th, 2010, 12:20   #5
cr9c1
Cool. We're going for master cylinder. It seems as if the clutch works fine then gets spongy the more you use it. We have replaced the slave cylinder already.
We have ordered a master cylinder for the clutch and it will be her Wednesday. We'll install then, hopefully this fixes the problem. Its acting like the pressure is bleeding off when you use it more and more, so I'm leaning towards master cylinder as well. If not, we'll go for clutch.
Old January 17th, 2010, 06:12   #6
TonyJetta
Post back and let us know how it goes.
Tony
Old January 17th, 2010, 07:16   #7
DieselFahrer
Default re : replacing the clutch master cylinder
If possible, use a pressure-bleeding apparatus to bleed the clutch
hydraulic system. A pressure-bleeder tends to give significantly better results, with respect to removing all the air bubbles from the system.
Also, removing the driver's seat makes the task of replacing the clutch
master cylinder a lot easier. It takes maybe two minutes to remove the
seat but it opens up some room so you can lie down where the seat used to be and deal with the R&R of the clutch master cylinder. It's usually quicker to go ahead and remove the seat rather than suffer with the contortions required with the seat in place.
And please do let us know how it goes.
Old January 17th, 2010, 08:19   #8
Mcgink
Mcgink's Avatar
If it's the clutch master, wouldn't the pedal push to the floor and stay there until you pull it back up? That's what would happen with my B4 when my clutch master was failing. Still much easier to replace the master before digging into the bell housing though. If the pedal just feels spongy, then you prob have air in it. Make sure that the brake reservior stays topped off during the clutch bleeding since the hose where the clutch draws hydraulic fluid from is higher in the reservior.
Mcgink is offline   Reply With Quote
Old January 17th, 2010, 09:07   #9
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
The throwout bearing might have failed. Enough spin of the flywheel side of the clutch is passing through the dragging bearing to spin the friction plate and input shafts to make shifting tough.
Svante Arrhenius 1896
Old September 7th, 2010, 09:19   #10
djbobo
Fuel Economy: 45-47mpg
Mines doing the same thing.
Any results on the master helping.
I think my line is infiltrating air because it will work for a minute after bleeding then go back to not (dis)engaging the clutch.
2000 Jetta TDI - 270k miles
97' Dodge Cummins - 245k miles
djbobo is offline   Reply With Quote
Old April 9th, 2011, 20:29   #11
aydn
aydn's Avatar
Hey guys any luck?
aydn is offline   Reply With Quote
Old April 11th, 2011, 10:26   #12
Ifixit
Ifixit's Avatar
Master - if there are no visible leaks outside of the lines/fittings or slave cyl and it works after bleeding then stops working soon and has air in system again.. replace master cyl
VW AUDI & TDI Repair in VT fullcircleauto@gmavt.net 802-496-9236
Vw Transmission, DSG Repair/Rebuilding
Petroleum Enthusiast
Ifixit is offline   Reply With Quote
Old April 1st, 2012, 06:17   #13
borrado512
Fuel Economy: avg. 50-54 mpg
Default 1998 VW Jetta TDI
Hey guys i got a problem on mine, the clutch pedal tends to suck in all the way down when u barely tap it and it stays down, i have replaced the clutch master cylinder on the pedal, replaced the slave cylinder, and just yesterday replaced the mechanical side of the clutch, and still no luck, pedal is still down. Any help would be nice
borrado512 is offline   Reply With Quote
Old April 1st, 2012, 06:57   #14
Yblocker
TDI(s): 1997 Passat
Might have been easier to start a new thread of your own rather than tagging
on to one that's 2 years old. Just sayin.
What do you mean when you say you "replaced the mechanical side of the clutch"? New clutch?
K03/04 hybrid turbo, RC II, Stage II Cam, Titan 502's, DC Stage I, TT LCA bushings
Yblocker is offline   Reply With Quote
Old April 1st, 2012, 07:12   #15
TonyJetta
Is the over center spring intact, just above the pedal?
Has the system been bled?
Originally Posted by Yblocker View Post
Might have been easier to start a new thread of your own rather than tagging on to one that's 2 years old. Just sayin.
Agreed...you'll get more specific attention to your issue, as well as troubleshooting history specific to your issue.
Tony
Page generated in 0.16659 seconds with 10 queries
[Output: 125.94 Kb. compressed to 104.89 Kb. by saving 21.05 Kb. (16.71%)]
