Go Back   TDIClub Forums > VW TDI Discussion Areas > General VW Discussion
General VW Discussion This is a place for General VW topics (the company, not your vehicle). General topics about a specific vehicle should be posted in the General TDI Dicussion Forum sections for that vehicle platform. A4, A3 & B4, B5, etc.
Closed Thread
Old July 31st, 2007, 04:22   #1
Brettwp
Default 2001 Golf groans when turning right
I have almost 140k miles on my Golf with little problem. But, recently I have noticed that when the steering wheel is even a few degrees right of center; it makes a groaning sound. Anyone have any idea of what that could be and what it would take to fix?
Brettwp is offline
Old July 31st, 2007, 05:12   #2
raybo
Fuel Economy: 2001 Golf (SOLD 11/15/15): 45 MPG avg mostly highway; JSW high 30's around town
Probably PS fluid - you must use Pentosin CHF 11S.
If you don't have the special tool to remove the cap, use a large pliers around the edge of the cap. Check the level while it's running. Keep it clean.
Ray
SOLD 11/15/15: 2001 Golf GLS 5-Speed Reflex Silver 391K
GOT 11/15/15: 2016 GSW S 1.8 TSI 5-speed Reflex Silver
2010 JSW DSG White Gold Metallic/Corn Silk 105K | Pano | Liqui Moly Top Tec 4200 as of 50K | Continental PureContact | built 11/09 (hers) HPFP disintegrated 12/14 - entire fuel system repaired by VWoA Jan 2015 at 93K miles
raybo is offline
Old July 31st, 2007, 05:24   #3
chinaloy
If you're low on PS fluid, then you should check for leaks, probably behind the inner tie rod ends at the rack.
To remove the cap, just lay down a small screwdriver in the cap slot.
chinaloy is offline
Old August 1st, 2007, 04:46   #4
Brettwp
Hey, thanks guys, you were right. I checked the PS reservoir, and saw that it was all but empty. Iím going to look for the Pentosin CHF 11S PS Fluid at the parts stores here in town, are there any other highly recommended brands, or ratings I should be looking for? My knee-jerk reaction was to assume that it was a wheel bearing, or some other high-dollar fix. If this is the cure, you guys saved me a lot of aggravation and expense.
Brettwp is offline
Old August 1st, 2007, 05:55   #5
cage
Watch for leaks!!!
I have similar mileage and guess what... Needed a new steering rack for $900.00
cage is offline
Closed Thread
© 1996 - 2020, All Rights Reserved
Page generated in 0.12009 seconds with 10 queries
[Output: 62.22 Kb. compressed to 54.56 Kb. by saving 7.67 Kb. (12.32%)]
