Old May 23rd, 2020, 17:16   #1
afterthisnap
Default ALH Wagon with high pinion Dana 60 full-floater.
In case my fellow rednecks ever wondered, it fit just fine without the knuckles .
Moog wagon springs and Koni orange shocks feeling the load:
The sister rear full-floater Dana 70-U only fit after the rear hatch trim sacrificed itself for a necessary 3"
afterthisnap is offline   Reply With Quote
Old May 23rd, 2020, 21:05   #2
Nero Morg
Nero Morg's Avatar
Oh lord. What's sad is I'd probably do this too, been looking for another Ford king pin Dana 60.
Whatever. Just use your darned blinker. And stay off your phone.
Nero Morg is offline   Reply With Quote
Old May 24th, 2020, 07:16   #3
mjydrafter
mjydrafter's Avatar
Are the Springs towing rated or standard?
Signed,
guy with Konis and towing springs.
Reading the title I was thinking "man, there is going to be some serious fabrication in here..." LOL
mjydrafter is offline   Reply With Quote
Old May 24th, 2020, 10:41   #4
Nero Morg
Nero Morg's Avatar
Same! I was actually hoping to see a monster wagon with a Dana 60 welded up front!
Old May 24th, 2020, 11:32   #5
afterthisnap
Moog 81005, I don't think they're officially rated as towing springs, but they definitely stink-bugged the butt end of the wagon when I first installed them.
Admittedly, the rear-sag/front-porpoiseing with the 60 is mostly a result of bad weight distribution. That plastic tote in the first post has fullsize rotors/hubs/brakes spare joints/Spare Us/Yokes and probably exceeds 200 lbs on it's own. There was also an ancient Forney cabinet welder jammed in there. Both were behind or over the rear wheels, thus contributing to the squat.
In contrast, the D70-U was a lot heavier on it's own, likely more than the 60 with accessories and the welder:
Without disassembling the 70 the weight was better spread out over the rear cargo area as the pumpkin rests just behind the rear seats.
Unloaded ALH Mule:
Gravid with Dana 70-U:
Addendum for some light reading, via Lugnut 4x4:
"The typical 14 bolt axle weighs about 550 pounds. Since there are many different variations of Dana 60 and 70 axles, we can’t give those axles a certain weight. However, a rear Dana 60 axle usually weighs about 400 pounds, a front Dana 60 will weigh about 500 lbs, and the Dana 70 is similar in weight to the 14 bolt.
The 14 bolt axle and the Dana 70 weigh more partly because they have 3.5″ axle tubes, which are slightly larger than the 3 3/8″ tubes found on many Dana 60s."
Old May 24th, 2020, 19:42   #6
[486]
TDI(s): 02 golf ALH
you can fit a 55gal barrel in a golf, sitting upright if you take the spare out
also, you can fit 8' lumber in a golf, and 10' in a jetta, just take out the passenger seat
Old May 26th, 2020, 05:02   #7
PakProtector
D70-U? With 3.08 gears? Did you leave the Cummins? Has it the 4-pinion Powr-Lok dual clutch diff?
cheers,
Douglas
1990 D250, NV5600, Luk 05-101, 16cm housing, TST Kit KDP tab, 366 spring, Powr-Lok'd 3.07, HX35...IC soon
She wasn't built to travel at the speed a rumour flies
2004 Jetta, 5spd...stock and turning 47-48mpg
PakProtector is offline   Reply With Quote
Old May 27th, 2020, 15:57   #8
afterthisnap
cheers,
Douglas
D70-U2, 4:10s, it was a V10+automatic, yes on the 4 pinion carrier but the Power-Loc is getting swapped for a Detroit.
WTB: AC compressor/ high low pressure switch / clutch full assembly chipmmm Private TDI Items for Sale/Wanted 0 May 7th, 2014 12:18
Thoughts on Dana VW in Northampton, MA MayorDJQ Eastern USA 9 October 17th, 2012 10:26
Dana VW is no more. MayorDJQ Eastern USA 2 January 27th, 2011 08:30
Spotted at Dana VW in Northampton, MA MayorDJQ TDI Cars for Sale/Wanted 0 February 17th, 2010 10:04
Dana Volkswagen Body Shop BeetleGo Eastern USA 1 March 26th, 2003 08:50
Page generated in 0.14981 seconds with 13 queries
[Output: 89.67 Kb. compressed to 77.23 Kb. by saving 12.44 Kb. (13.87%)]
