Old May 23rd, 2020, 10:32   #1
Darkniss81
Default The big 3
Does anyone know where the ground is for the engine to chasis on a 2013 jetta sedan tdi
Sent from my SM-G930W8 using Tapatalk
Darkniss81 is offline   Reply With Quote
Old May 23rd, 2020, 10:42   #2
mu3098
should be under the air filter box and bolts on to the engine by the starter motor.
mu3098 is offline   Reply With Quote
Old May 23rd, 2020, 12:07   #3
eddieleephd
Fuel Economy: 38mix / 47@70-75
http://gridlox.net/files/golf6grounds.pdf
Found it here
https://forums.tdiclub.com/showthread.php?t=388590
Found it using this
https://cse.google.com/cse?q=+&cx=01...44:_idbzjdyxdm
Sent from my moto g(7) power using Tapatalk
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, Bosio DLC 1019's PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is online now   Reply With Quote
Old May 23rd, 2020, 12:58   #4
Mongler98
BTW, get some quality wire. go to places like capitol tristate or other commercial electrical supply stores. buy K welding lead wire. you wont regret getting some quality stuff, if you go with most of the big 3 kits out there, they all suck so much. most of them are CCA or Copper clad aluminum. aka the worst wire known to man. along with many issues, i would stay away from kits and make your own with quality connections rated for the wire you get (preferably 1/0 gauge). Use crimp down lugs then solder them and shrink wrap with 3m glue wrap for exterior use. avoid anything with allen keys lol
K welding lead wire is IMO the only way to go.
Old May 23rd, 2020, 13:19   #5
Darkniss81
Thanks that's exactly what I have already started
request for big mileage on big torque motors. noxneon TDI Power Enhancements 26 November 10th, 2013 07:21
IDParts Exclusive TDIFest Specials! Big Discounts on Big Stuff! cevans TDIFest 2013 18 August 29th, 2013 10:28
Jeep, VW Roll Out Big Diesels in the Big Apple dieseldorf Non VW Group Diesels 7 April 22nd, 2007 10:28
BP gets big lift from big oil prices, Profits Rise PDJetta Fuels & Lubricants 1 October 25th, 2005 21:57
Page generated in 0.12298 seconds with 12 queries
[Output: 67.66 Kb. compressed to 59.78 Kb. by saving 7.89 Kb. (11.65%)]
