Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Other VW Group TD(I)s
Other VW Group TD(I)s To keep with the theme of VW Diesels, this message area is for discussion of other VW Group Diesels. Yes, TD's are also welcome.
Old December 17th, 2012, 13:08   #61
jamesdean
jamesdean's Avatar
Default 2.0 TD parts from your aborted build
I've stumbled across this thread in my search to put a 2.0TD into my Quantum Syncro Wagon and wonder if you still have any of the 2.0TD parts.
I've found a 2.0TD which will be shipped to me from Canada in January and would like to (much like you did) start accumulating the necessary known parts, head gaskets, etc. to start refurbishing the engine. I'd be interested in most everything you had for this engine. I'll PM you after sending this.
J.D. in Reno
'06 Touareg V10; '97 Passat TDI; '96 Chevy K2500 6.5 TD; '85 VW Jetta 1.6 TD; 1985 & 1987 VW Quantum Syncro Wagons (will convert to 2.0 TD); 1985 Volvo 2.4 TD; '82 Caddy getting a 1.6 TD;
jamesdean is offline   Reply With Quote
Old December 18th, 2012, 15:14   #62
jackbombay
jackbombay's Avatar
TDI(s): A4 Jetta
Fuel Economy: 57/43/32
You will need the drivers side motor mount from the 5 banger gasser to install the 5 banger diesel into the quantum. other than that you just need a shoe horn!
Hp vs. TQ
jackbombay is offline   Reply With Quote
Old December 19th, 2012, 02:43   #63
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
jackbombay: He's already got a Quantum Syncro Wagon, which means that it has 5-banger motor mounts from the factory.
Originally Posted by Upton Sinclair
It is difficult to get a man to understand something, when his salary depends upon his not understanding it!
bhtooefr is online now   Reply With Quote
Old December 19th, 2012, 07:11   #64
jamesdean
jamesdean's Avatar
There's an Audi 4000 and 5000 gasser in my local Pick n Pull, which mount should I get?
J.D. in Reno
Old December 19th, 2012, 07:15   #65
jamesdean
jamesdean's Avatar
Default About the shoehorn.
JackBombay, I plan on removing the front grille and headlight support panel and squeeze it in from the front after removing all the electrical related to the gasser.
J.D. in Reno
Old December 22nd, 2012, 10:51   #66
jackbombay
jackbombay's Avatar
TDI(s): A4 Jetta
I was just letting him know that he does need to hang onto that one motor mount.
You shouldn't need anything from the junkyard, just hang onto the drivers side motor mount from your gasser.
that will make it easy
Hp vs. TQ
Old January 1st, 2013, 19:33   #67
jamesdean
jamesdean's Avatar
Thanks again for the tips. Jack, I found your original build thread and reviewed it as well as this one. There's several photos missing from your thread but I get the general idea of what you did. I'm going to start a build thread at the vwdieselparts.com site so I can keep track of what I'm doing and also get your input as I move along. J.D.
J.D. in Reno
Old February 6th, 2013, 08:06   #68
ecodiesel1
TDI(s): 97 Jetta
Hi Jamesdean, Hows your project coming? I have one of these to go into my 81 5000 diesel NA. I'd love to stay in the loop on your project and progress.
Also I was looking for Tooef, I was wondering if he still needed a head or if he's moved on from the project. I may have a head for him he can use. And if he's moved on i'd really like the rest of that engine, as I'd like to TD my 4k winter car.
So glad to hear of others running the ol' 2.0 TD. Its hard to find a good group of guys running it!
ecodiesel1 is offline   Reply With Quote
Old February 7th, 2013, 09:01   #69
jamesdean
jamesdean's Avatar
Very interesting timing on your question. I just got the engine running on a stand last night. I haven't figured out the adjustment for idle speed and timing advance but the thing sounded real strong. Sometimes it would idle o.k. at low rpms then sometimes when I would push the acellerator it would come back to a VERY high idle, it sounded like it was about 1/3 to 1/2 throttle, so I could only let it run for 20 - 30 seconds.
I had contacted Tooef via PM and he had given up on the project. He still has a box of parts that I may get.
I'll post my updates on the vwdiesel.net site, I'm just slow at getting things uploaded there. Here's the thread as it exists now: http://www.vwdieselparts.com/forum/v...11768&start=15
J.D. in Reno
Old February 7th, 2013, 09:16   #70
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
OK, I'm confused now.
Because I'm who everyone calls tooef, and I was interested in this project, but it wasn't mine, and you didn't PM me. Are you talking about GTiTDi?
Old February 7th, 2013, 22:50   #71
jamesdean
jamesdean's Avatar
My error in the reply. I did PM GTITDI about his leftover parts.
J.D. in Reno
Old February 9th, 2013, 20:05   #72
v8volvo
TDI(s): 2001 Jetta
Sounds like a sticky governor plunger in the IP. Often when they sit for a long time the control collar or the gov plunger or both end up having trouble moving easily once you get them going again. Be careful running it while it's that way, since your ability to regulate engine speed is compromised and without the motor hooked to a transmission and clutch in a car, where you can stall it if it begins to run away, your only option if it starts to get away from you is to quickly choke off the air inlet or slice the fuel line. Demands quick thinking, which in the heat of the moment is not always easy.... if you catch it quick enough pulling the wire off the stop solenoid can shut it down, but as I have had the misfortune to discover on more than one occasion, once the engine speed gets beyond a certain point the solenoid can't push its piston down hard enough to block off the fuel flow.
Filling the IP with biodiesel or diesel purge and letting it sit a while can free parts up sometimes, worth a try. Good idea to keep a chunk of wood nearby whenever you run it, ready to block the turbo inlet with if things get out of hand...
Idle speed is adjusted via the throttle lever stop screw on the engine side of the top of the IP, and is also affected by the position of the fuel limiter screw; however if you've got sticky parts inside the pump adjusting idle externally might not give you very good results until after you have got all the internal controls moving happily.
Sounds like fun, good luck getting it together!
v8volvo is offline   Reply With Quote
Old February 10th, 2013, 09:11   #73
jamesdean
jamesdean's Avatar
Default Good idea on the IP internals
You're right about quick thinking on the shutdown. Fortunately the fuel solenoid wire was close to hand and worked as it should. I'll keep a small block of wood near the turbo inlet in case that doesn't work. I was just going to put my hand over it, but that is obviously a bad idea when it's turning that fast.
I did run a bunch of ATF through the pump prior to firing it up but I think you're right that there's some gunk in there. (I had all the injectors out and just used the starter to spin it over to prime the pump and move fuel through the system.) Today I'm going to remove the lower small cover and see what drains out. I'm talking about the cover with the 2 screws that cover the advance mechanism on the 1.6 pumps. If there's any dirty water I can force it out with air, or just let it drain out. I will get some diesel purge and put it in after.
It did run much more consistently yesterday. I created a temporary cooling system so I could run it for longer periods (as long as I want) and it ran good and idled satisfactorily most of the time. I did adjust the external idle screw. The throttle linkage was also bent down and was just touching the manual shut off valve so I think it was sticking a little there also. Any rpm surges were much milder and I only had to shut it down once when it stuck at about 1/3 throttle.
As a bonus, I finally understand the coolant flow and the function of the thermostat that closes off the block port once the engine warms up. I marvel at the engineering on these engines! As the thermostat opens, the back end of the thermostat closes the water port on the flow coming out of the head at that port. Once fully opened the water flow through the head then all flows out the back of the head/block.
J.D. in Reno
Old February 10th, 2013, 10:17   #74
v8volvo
TDI(s): 2001 Jetta
Yeah, it is an interesting setup. The only major drawback to it that I am not impressed by is that the thermostat's location does not ensure that it always sees the hottest coolant in the engine, and the temp of the coolant that does flow past it is subject to a certain amount of variation based on how hard you are running the heater, even while coolant temp in the engine itself is constant. Most of the coolant that runs by the t-stat wax pellet has first passed through an external circuit somewhere (oil cooler, cold start thermostat, heater core) so not only is there some degree of temperature differential versus the coolant in the cylinder head, that differential is not constant, depending on other outside factors. Meanwhile, the sender for the temp gauge is mounted right in the end of the cylinder head, not far from the #1 prechamber, which means it is measuring cylinder head temp pretty directly, but is far away from the t-stat..... resulting in considerable fluctuation of the coolant temp in the cylinder head and corresponding fluctuation of the reading of the temp gauge, especially when the engine is running under heavy load.
The 2.0L five and 2.4L six-cylinder motors have a particular tendency towards headgasket failure and head warpage, which to me indicates a problem with temperature control.... mainly, IMO, that the coolant in the head may be considerably (and variably) hotter than the coolant reaching the thermostat. A slightly cooler-than-stock thermostat seems to go a long way towards stabilizing running temp on these units. An 87c thermostat is OK if that's where the whole engine is running, but if the coolant in the head is 20c hotter than that, can lead to trouble... After having done four 2.4L headgaskets in the past year I have started putting in a Wahler 80c tstat in every one that I work on, seems to make no difference in heat output or gauge reading but keeps the needle from climbing on hills. YMMV
Old February 16th, 2013, 07:36   #75
jamesdean
jamesdean's Avatar
I agree with your observations. Running the 80C thermostat will help but there's still a large temperature variation within the system. Here's a link to "Herman's" engine rebuild page that shows how he made a water outlet port on the back of the head. He removed the tapped plug for the water temp sender to make the outlet: http://picasaweb.google.com/itzdshtz...47187197938770. He drilled and tapped some mounting holes then fabbed an elbow for the pipe connection here:
http://picasaweb.google.com/itzdshtz...46113456114738.
If you look at the rest of his blog you can see he has a machine shop that few have, but he's done a lot of custom work to the engine that will definitely improve the cooling. My question is: where does he connect the flow from the back of the head? It seems it would be better to run it right into the upper radiator so that after the system heats up and the thermostat opens (and the thermostat closes the port from the head) the flow would be forced into the radiator.
He also made an engine prelube pump to circulate oil throughout the engine prior to startup here: http://picasaweb.google.com/itzdshtz...75418389488114. That's a great idea but even after reading the text I don't understand how he did it. His description of the pump is near the bottom of this page: http://vanagonsyncroproject-herman.blogspot.com/
J.D. in Reno
FS Audi Vw 5cyl 2.0 Turbo Diesel engine IDI riverbeetle Private TDI Items for Sale/Wanted 3 March 24th, 2012 04:32
Audi 80 5cyl to TD conversion Katada Other VW Group TD(I)s 0 August 26th, 2011 22:46
Audi 2.5 Tdi 5cyl power loss Leo__ TDI 101 0 October 29th, 2008 03:58
Audi A6 C4 TDI 2.5 104Kw 5cyl. boji55 TDI Power Enhancements 1 August 20th, 2008 08:29
any one have any info on 5cyl turbo diesels? vw/audi/volvo?? therabbittree TDI Power Enhancements 3 July 27th, 2000 05:00
Page generated in 0.19688 seconds with 13 queries
[Output: 140.34 Kb. compressed to 118.00 Kb. by saving 22.34 Kb. (15.92%)]
