Oregon Implant
I am looking for information regarding the model year 1999.5 Jetta. Is this a good model or one to stay away from. I do not currently own a TDI and am considering one at this time. Any information would be helpful.
You could get crank windows until 2002 I think? The 99.5s just came out of the extended warrenty on the window lifters. I only had to have mine fixed 5 times... LOL.JasonMc said:I...One thing I like about the 1999.5 GL is the hand crank windows. I think they went to all power in 2000. I don't ever have to worry about a damn window regulator! Also with a 1999.5 you are for sure getting the older style good clutch (sachs).
Yeah, forgot about the stupid leftover A3 shift linkage on the '99.5compu_85 said:You could get crank windows until 2002 I think? The 99.5s just came out of the extended warrenty on the window lifters. I only had to have mine fixed 5 times... LOL.
99.5s got a LUK clutch as opposed to the less-highly-specified Sachs unit in the later cars. That is one plus. Notice that the 99.5 golf/ jetta have transmission code EGR, and they were the only ones fitted with that transmission. The ratios are the same, but the linkage is different. As me how I know...
-J
How do you know? Just kidding.compu_85 said:Ask me how I know...
Really? I was looking to buy new keys for mine and was adding the cost of the dealer having to program the immobilizer. Are you sure I wont have to do this?Souzafone said:no immobilizer to lock me out
Has anyone ever done the linkage and shifter swap out? I have a 99.5 and the shifting is the only thing I don't like about it. I am not opposed to buying the parts to make it shift right, I would just like to know what parts to buy and swap to make it work right.oilhammer said:The transmission in your A4 is the 02J, which is almost identical to the 02A used in the A3 except the mounting arrangement and the provisions for the different bellhousing due to the oil pan bolts. However, the shift linkage both on the trans and inside the car, as well as everything inbetween, is more of the design like the 02A used. But for some reason, the early A4 02J linkage like the '99.5 (and NB from '98 to '99) have some issues with getting sloppy and breaking the plastic pivot on the trans as well as stripping the splines off of the shift tower on the trans.
VAG always improves cars, every year (sometimes even inbetween years), so the best MY for any given platform is almost always the last MY. Simply because it will have all the improvements.
Luckily, many of those improvements can be retrofitted on to earlier cars. VAG products are one of the best lines of cars out there for plug-n-play changeout of stuff. Your shifter, for instance, can be swapped out for one from a 2000+ car and you will gain all the benefits of the newer cars. What happens though is sometimes some of these items can become cost prohibitive. For instance, if you wanted the improved ECU and CAN system of a 2001+ car, you would need the entire wiring harness, cluster, ECU(s), N75 valve, MAP sensor, etc. A huge undertaking that is really not worth the effort but some people still do this.
Same thing happened with the A3 platform, except the TDI crowd never really knew any different because by the time we got a TDI engine offered in an A3 it was the end of the platform "tier 1" life span. But countless improvements were made to the A3 between its debut in 1993 and 1998, the most noteable changes happening in the '95 and '96 era cars. The '98 and early '99 A3s were by far the best.
Sit in car and extent your right hand....everything after your hand all the way to the shift forks in the transmission is what needs to be changed.Mike_Parker said:Has anyone ever done the linkage and shifter swap out? I have a 99.5 and the shifting is the only thing I don't like about it. I am not opposed to buying the parts to make it shift right, I would just like to know what parts to buy and swap to make it work right.
Basically, the early A4 cars had the same shifter setup as the A3, only for some reason they always seem to get really loose and sloppy (even worse than the A3s do). When they were new it was fine, but as they age they get really sloppy. If you drive a 2000+ one you will immediately know what I mean. Even after 200k miles, they are still much tighter and more positive than the older ones.egibbys said:How has the shifting been improved from the 99.5? Sorry all I’ve ever driven are 99.5s. Is it that much better that I may want to swap it out?
hmm... looks like I'm going to have to find a newer car to drive for a comparison. Cause my car feels "normal" to me and it has 201,000 miles on it. Out of curiousity how expensive are the part(s)?oilhammer said:Basically, the early A4 cars had the same shifter setup as the A3, only for some reason they always seem to get really loose and sloppy (even worse than the A3s do). When they were new it was fine, but as they age they get really sloppy. If you drive a 2000+ one you will immediately know what I mean. Even after 200k miles, they are still much tighter and more positive than the older ones.
It is just an improved design is all.
