christi
I turned my Passat TDI into a seven seater (well sort of) here are the pics.
1: Put two plates up at the front of the load space.
Each plate is about 4mm thick steel.
I drilled each and tapped 10mm threads into the holes.
Then I drilled hole through the boot floor.
I also removed the thick sealant that covered the boot floor (just underneath the plate) so that the plate is against metal, and it a bit more flush.
Then I pulled two M10 bolts up through the hole with a piece of string, and threaded them up into the plate.
Then I locked to nuts onto each bolt, so that I could turn them with a wrench (you can't get at them from under the car, they are in a recess above the exhasut system on one side, and above the fuel tank on the other).
Lastly a ground off the excess bolt, so as to get a flush finish.
Each plate has two M10 bolts with big washers holding it down to the floor.
2: Put two plates at the back of the load space.
These are down in a similar way, with holes drilled into the rear box section and then M10 bolts pulled through the the holes with string, and threaded into an M10 thread that I made in each angled plate.
3: Then I made the actual seat itself
This is made with two pieces of plywood, and lots of steel angle section lengths. All of the critical points are held together with steel plates, such as where the seat belts screw to the seat frame.
The seat is screwed down to the floor plates with four M10 bolts.
It can go in front facing like this, which means that one of the middle seats has to be folded so that the child can clamber into the load space.
Or it can be screwed down the other way around.
Kindly modelled by my near two year old daughter, Maria.
Its not a perfect solution.
The whole thing would have to be removed to get at the spare wheel if I had a puncture.
I will have to add head restraints to take a child much bigger than Maria, and in forward facing mode I will have to move the seat forward a bit as it is right up against the tailgate glass and the slode of the glass does not give room for a head restraint where it is.
It doesn't fold, so has to be removed completely it any load space is wanted.
