How to check timing belt with unknown years/ miles.
Timing belt kit replaced....Check!
If there is anybody who can tell you the reason for replacing a timing belt, it's me.
I would guess that roughly 1/2 of thousands of cylinder heads we have rebuilt are due to misinformation from the previous owner. "...Just had a timing belt done..." (That is code for they replaced ONLY the timing belt and nothing else. The big roller, tensioner water pump, belt teeth...blew up and I get the cylinder head..), or the customer figures the timing belt will go 100,000 miles, but completely forget it's 100k OR 5 years... So, unless you want a really great rebuild on your cylinder head, my advice, avoid my excellent cylinder head service. Get a timing belt installed. Follow good advice or get someone whose done a few hundred to install yours.
We offer a very good timing belt kit, loan the tools and can provide excellent Phone/ email technical support.
As for removing the valve cover, I would, but not because you need to when replacing a timing belt. We remove the valve cover to see if there is any adverse wear on the cam. The PD's have a premature wear issue with the cam. If you see galling on the base circle of any cam lobe, you should remove the cam, cam bearings and cam followers and replace them.
We have a very good guide for removing the cam for inspection and unlike a popular one that is out there, it avoids an issue that can cause the tandem pump driver to break. Let us know if you can be any additional help.
