fuel tank lid, hatch lid, d/s mirror and door
lafrenpr
ottawa
2002 volks jetta tdi
i have a 2002 vw jetta tdi 1.9, standard
fuel tank lid and rear hatch wont open . d/s mirror wont work and d/s door will not lock. i think the problem may be in wiring between d/s door and car frame. i was able to open fuel lid via applying 12 v directly to proper wire inside the driver's door fuel lid switch.
any ideas.
I am electronic tech. i have checked fuses. all ok. there appears to be no power going to d/s door
Mongler98
COLORADO (SE of Denver)
OK, sooooo, pull back the accordion in between the car body and the door, i bet you have some broken wires. Fix them, with solder, a patch wire, some shrink wrap and so on. common issue. Get to working. post results
lafrenpr
ottawa
Thanks,
I just wanted to make sure before I splice it open, It is probably the power line common to all those devices.
I will post results
Mongler98
Thanks,
I will post results
it should pull back easily, no need to splice
