Old June 13th, 2018, 10:46   #1
Nohlan_4
Default How to BRM Turbo R&R?
Based on this thread: http://forums.tdiclub.com/showthread.php?t=489086
Getting ready to complete this job. From what I have found on the forum already this seems liked the easist way out through the bottom.
Intercooler output to ASV pipe
- Intake adapter to the turbo
- VNT harness
- O2 sensor - I would cut a wrench short or get the VW tool
- Exhaust
- Oil return tube
- EGR cooler to EGR manifold
- EGR cooler; I left the coolant hoses attached so I didn't have to drain my coolant.
A couple questions though. Can I pinch the coolant lines off on the egr enough to keep the coolant in the car so I don't need to refill the system? Also the oil return line when I pull this off will I lose all the oil out of the engine? Should I drain the oil before I start? Does the axle need to come right out or just unbolt the flange, size of 12 point is 10mm?
Anything else I will need or should plan for?
Nohlan_4 is offline   Reply With Quote
Easiest way to R&R 2006 BRM Jetta Turbo dtreid VW MKV-A5 Golf/Jettas 7 May 22nd, 2018 14:01
FS: 2006 BRM Turbo Kit & Downpipe TDI817 Private TDI Items for Sale/Wanted 12 January 17th, 2017 07:32
Jetta MK5 brm egr cooler & Turbo & odd parts burtblade Private TDI Items for Sale/Wanted 2 April 10th, 2014 16:06
Wanted Turbo & parts for BRM TDI817 Private TDI Items for Sale/Wanted 1 October 29th, 2012 02:09
BEW & BRM turbo smart actuators F/S $60 shipped aNUT Vendor & GroupBuy items for sale 13 April 17th, 2012 05:57
Page generated in 0.10758 seconds with 11 queries
[Output: 47.07 Kb. compressed to 44.38 Kb. by saving 2.68 Kb. (5.70%)]
