D-Cell_Mekanick
I scanned my car after the DEF froze on the way to work the otherday. I found a few errors that perplex me, any help deciphering these would be appreciated. Engine faults are due to frozen DEF, it was -17*F when I left for work, light and message came on 40 miles into drive. Thanks in advance.
Tuesday,11,February,2014,20:17:27:61907
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Dealer/Shop Name: Jason's Garage
VIN: 1VWCN7A37EC****** License Plate: MY PASSAT 1ST SCAN
Mileage: 1137 Repair Order:
Chassis Type: A3 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 75 77
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CKRA) Labels: None
Part No SW: 03L 906 012 DE HW: 03L 907 309 S
Component: R4 2,0L EDC H24 6073
Revision: 71H24--- Serial number:
Coding: 001D0012042400008000
Shop #: WSC 09003 957 00200
ASAM Dataset: EV_ECM20TDI01103L906012DE 004004
ROD: EV_ECM20TDI01103L906012BN.rod
VCID: 6AD13ED28D8E3A4E2A7-803F
2 Faults Found:
20553 - Reductant System Performance Bank 1
P204F 00 [232] - Malfunction
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 1729 km
Date: 2001.14.30
Time: 06:11:16
4891 - EGR Valve (N18)
P0403 00 [096] - Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 1729 km
Date: 2001.14.30
Time: 06:11:16
Readiness: 1 1 0 0 0
Address 02: Auto Trans Labels: None
Part No SW: 02E 300 062 B HW: 02E 927 770 AL
Component: GSG DSG AG6 521 4020
Revision: 05652104 Serial number: 00001309091290
Coding: 0000020
VCID: 142D402A378A5CBE20B-8041
No fault code found.
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: C54BC0F549270002A30E03E592210042A1100012
VCID: 7EF90282E906A6EEE6F-802B
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 086 1101
Revision: 00086000 Serial number: 0194647668
Coding: 130C0C
ASAM Dataset: EV_KESSYPQ35G A02013
ROD: EV_KESSYPQ35G.rod
VCID: 346DE0AA9FCABCBE40B-8061
1 Fault Found:
1057547 - Antenna for Keyless Entry System; Interior Antenna 1
B1172 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 42
Mileage: 17 km
Date: 2001.14.16
Time: 17:49:23
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 561 907 044 AF HW: 561 907 044 AF
Component: Climatronic H03 0606
Revision: 00001K02
Coding: 0030019012
ASAM Dataset: EV_ACClimaBHBVW411 A01001
ROD: EV_ACClimaBHBVW411.rod
VCID: 5BBF6B1652D453C6A11-800E
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0173
Revision: BL122001
Coding: EF200E1B982B08D4098802012600854800F1A086458015B064806000BC70
VCID: 78F5149ACB2298DEAC3-802D
1 Fault Found:
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 43
Mileage: 24 km
Time Indication: 0
Date: 2001.14.16
Time: 18:16:38
Freeze Frame:
Term 15 On
Voltage: 14.55 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
Component: AirbagVW10G 014 0851
Serial number: 003MWM03NPJK
Coding: 00005033
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 75EB1DAED430E5B6B75-8020
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y13000108MN0P
Coding: 303047
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME7740527EZZZ$
Crash sensor for side airbag; passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME5818647DZZZ3
Crash sensor for side airbag; rear driver side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME290C7427ZZZW
Crash sensor for side airbag; rear passenger side:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME12394B28ZZZU
Crash sensor for front airbag; driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME5B405A28ZZZ$
Crash sensor for front airbag; passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME0A275D28ZZZ%
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20130913201280
Coding: 000A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DFB058EEC00BDF6FF5-8028
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-YVJ H07 0022
Coding: E20000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 561 920 970 G HW: 561 920 970 G
Component: KOMBI H04 0811
Serial number: 00000000000000
Coding: 231E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 1E392202014606EE86F-804B
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 09111303000252
Coding: 461000
VCID: 7BFF0B96FA14B3C6C11-802E
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0811
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EAD1BED20D8EBA4EAA7-80BF
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000210811003
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 3065ECBA6BD2809E243-8065
Address 2E: Media Player 3
Cannot be reached
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 561 959 760 B HW: 561 959 760 B
Component: MEM-FS H04 0182
Revision: AA000000 Serial number: 00000078586980
Coding: 00581B0000000000000021010100202020202120202020
VCID: 224116F23D3E220EA27-8077
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 L HW: 3C0 035 684 L
Component: RNS-MID H22 5374
Revision: AB001001 Serial number: VWZ6Z7N8330034
Coding: 04090042010000A6000B
VCID: 2C5DF8CA4FFAE47E18B-8079
Subsystem 1 - Part No: 7L6 919 859
Component: NAR V7 8050
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 68
Mileage: 29 km
Time Indication: 0
Date: 2001.14.17
Time: 17:56:20
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0007575330
Coding: 0405FD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1C3D280A175A14FE68B-8049
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B
Component: J388__TSG_HL 006 5470
Serial number: 14202630131118170430
Coding: 800000
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 290 3501
Revision: 00H22000
Shop #: WSC 01357 011 00200
VCID: 3973D19E70A841D693D-806C
Address 47: Sound System (R12) Labels: 3T0-035-456.clb
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: -------- Serial number: EAA098A0083855
ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
ROD: EV_AudioVerst10KanalSTT3.rod
VCID: 26490AE25916DE2ECEF-8073
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1642
Coding: 01030108
VCID: EFE7AFC63E6C5F66FD9-80BA
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0007623068
Coding: 0405FC
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D3B250E0C401DF69F5-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B
Component: J389__TSG_HR 006 5470
Serial number: 14102631131126150050
Coding: 800000
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 68
Mileage: 29 km
Time Indication: 0
Date: 2001.14.17
Time: 17:56:20
Address 75: Telematics (J949) Labels: None
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0086
Serial number: 000003554140511
Coding: 02140102C2423A007F1606000000
ASAM Dataset: EV_OCULow 001010
ROD: EV_OCULow_VW12.rod
VCID: D3AF0336BA041B86F91-8086
3 Faults Found:
12670464 - Databus
U1121 00 [008] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 58
Mileage: 929 km
Date: 2001.14.24
Time: 14:46:05
0035 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 58
Mileage: 90 km
Date: 2001.14.17
Time: 20:19:40
2103041 - Control Module Blocked
B2017 00 [009] - -
Freeze Frame:
Fault Priority: 8
Fault Frequency: 1
Reset counter: 28
Mileage: 1830 km
Date: 2001.14.30
Time: 20:12:11
Address 77: Telephone (J412) Labels: None
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0315
Revision: 1B001001 Serial number: 00007665472144
Coding: 0A10030080010110
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI_SE36.rod
VCID: 2E59F2C271E6966E36F-807B
1 Fault Found:
9457664 - Function limitation due to excessive temperature
B1050 00 [008] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 59
Mileage: 7 km
Date: 2000.14.29
Time: 13:17:36
End ---------------------------------------------------------------------
52 56 62 72 75 77
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 1729 km
Date: 2001.14.30
Time: 06:11:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 1729 km
Date: 2001.14.30
Time: 06:11:16
Coding: 0000020
Revision: 00H46001
Coding: 130C0C
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 42
Mileage: 17 km
Date: 2001.14.16
Time: 17:49:23
Revision: 00001K02
Coding: 0030019012
Revision: BL122001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 43
Mileage: 24 km
Time Indication: 0
Date: 2001.14.16
Time: 18:16:38
Freeze Frame:
Term 15 On
Voltage: 14.55 V
ON
ON
OFF
OFF
OFF
Coding: 00005033
Coding: 303047
Coding: 000A140000
Coding: E20000
Coding: 231E01
Coding: 461000
Serial number:
Coding: 000007
Cannot be reached
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 68
Mileage: 29 km
Time Indication: 0
Date: 2001.14.17
Time: 17:56:20
Coding: 0405FD
Slave Driver:
Coding: 800000
Revision: 00H22000
Coding: 01030108
Coding: 181100
Coding: 0405FC
Slave Passenger:
Coding: 800000
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 68
Mileage: 29 km
Time Indication: 0
Date: 2001.14.17
Time: 17:56:20
3 Faults Found:
12670464 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 58
Mileage: 929 km
Date: 2001.14.24
Time: 14:46:05
0035 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 58
Mileage: 90 km
Date: 2001.14.17
Time: 20:19:40
B2017 00 [009] - -
Freeze Frame:
Fault Priority: 8
Fault Frequency: 1
Reset counter: 28
Mileage: 1830 km
Date: 2001.14.30
Time: 20:12:11
1 Fault Found:
B1050 00 [008] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 59
Mileage: 7 km
Date: 2000.14.29
Time: 13:17:36
