Cincojoe
How do you determine what year your car was built?
Yes, since cars are built to model-year-specific requirements. While not a hard and fast rule, usually August is the production cutoff month. So a July of 1998 car will be a 1998 model, while an August of 1998 car will be a 1999 model. However, since these model year requirements are in place well ahead of time so the car companies have plenty of advance notice to design in compliance, there is no reason why they cannot build a newer model year car, even a couple years out. This is why you find instances where an all-new model was designed around upcoming requirements, and they just went ahead and built them to that year's compliance. Like the 2012 model year Passats that were at the NAIAS in January, complete with valid VINs and a 'C' in the 10th spot.Interesting, than you. So that 10th digit only tells you the year, not month? I'll check the door when it stops raining
