Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old January 12th, 2018, 12:06   #1
soldierguy
Default Your thoughts on high mileage TDI ownership
Hey all, itís been a long time since Iíve nosed around here. I used to have a Ď10 Golf TDI, but sold it to get a motorcycle back in 2011.
Hereís the deal. Iím now a supercommuter, and have been for almost 2 years. My daily round trip commute to and from work is about 225 miles, and all but about 10 miles of that is highway. Fantastic job, and the overall situation will be the same for the next 2-3 years at least.
When I found out I got the job, my first thought was ďI need a TDI.Ē Then the emissions thing hit, the TDIs were no longer for sale, so I didnít get one. Iíve been driving a Ď16 Prius for the last 20 months, and Iíve got slightly north of 91,000 miles on it (I bought it new). It has been as reliable as a stone. Gas, tires, oil, filters, and wipers are all that Iíve needed to do to it. My commute has headwinds from hell half the year, so Iíve averaged 48.9 mpg since Iíve had it. Around town, without trying, I can average north of 60 mpg.
I canít fault the reliability, fuel economy, and low maintenance costs of it. But itís a Prius...Iím sure you understand. I despise the climate controls and stereo...WAY too complex, requiring too much eye time off the road to do simple things...they cannot be operated by feel. Mine has the new-for-Ď16 lithium ion battery...not much history on the longevity of those, and honestly, people on the Prius forum Iím on are starting to look at me as a test monkey for longevity of the current generation Prius.
Saw two certified pre-owned Ď15 Jetta TDIs on the local dealerís lot, both with DSG. The S has 12,000 miles and is priced at $14,000, the SE has 28,000 and is priced at $13,800. I like the SE better because itís got a few more niceties on it.
Iím tempted to trade the Prius in on one of them. I like the idea of the extended engine & emissions warranty, but being a VW (Iíve had 5), I know itís not likely to be as rock solid reliable as the Prius. Iíve seen posts here about water pumps going bad, various check engine lights, and I know the DSG is expensive to service. But Iím still thinking about it.
How do these hold up over the long haul? Is it a constant stream of small issues (or larger ones)? Or do they do well when maintained and driven all-highway? Iím religious about maintaining vehicles, and I donít beat on them.
Thanks in advance for your thoughts.
Soldierguy the SuperCommuter
'15 Jetta TDI S DSG
soldierguy is offline   Reply With Quote
Old January 12th, 2018, 12:16   #2
The type of driving you do (long distances at highway speeds) is ideal for a diesel. We have a number of customers with '10-14 TDIs that have well over 200K miles on them with relatively few problems. And the new emissions warranty will help cover any emissions system related failures (including the high pressure fuel pump) that might arise.
I think you should do it. You may not see quite the same FE as the Prius, depending on how fast you drive, but I'm betting you'll enjoy that long commute more. 225 miles a day in a car is a lot.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old January 12th, 2018, 12:29   #3
soldierguy
Thanks! My speeds are about 68-70 mph for half the drive, 73-75 mph for the other half. The headwinds are a prevailing weather phenomenon. On the way to work I gain about 1500 feet in elevation (gradually) and have usually a 2-5 mph headwind. On the way home from work, I lose the elevation, but have a 15-20 mph headwind for more than half the year, maybe 10mph headwind for the rest of the year. On those rare days with no wind, the trip computer reads a whopping 10 mpg higher than on days with the wind.
'15 Jetta TDI S DSG
Old January 13th, 2018, 10:58   #4
fastcar4re
Those prices seem reasonable, and you'll have a warranty to cover the drivetrain and emissions system. It's worth a shot because 2015 is the last year for the Jetta TDI, but the EA288 engine is new in many ways, so I can understand your concern. I only have 5,000 miles on my 2015 TDI SEL that I bought "new" in May 2017, and I really like it, so I can't comment beyond "I like the car." I drove a 2005 Passat TDI since new before my 2015 Jetta (13 years and 150,000 miles). The other way to look at your situation is that you can always go back to a Prius or something else if the Jetta TDI does not work out for you, but you'll probably not ever get a chance to drive a near-new TDI. A handful of people have caught a "whiff" of coolant due to failing water pumps, but that can be sorted out under warranty. Finally, if you do go the TDI route, you can be the "high-mileage-guy" on this forum and report back on any issues.
fastcar4re is offline   Reply With Quote
Old January 18th, 2018, 09:26   #5
Slurry Pumper
I have a 2010 Jetta TDI, and also have a long commute, although at 150 miles a day it is obviously shorter, and I have had this commute for the last decade, although I only go into the office around 3 times a week now-a-days. My commute is half 2 lane road with a few stop lights, and half turnpike 80+ mph driving.
I bought my car new, and it has around 200K on the clock. As a reliability engineer now, and even as a Pump engineer a few years ago (hence the tag), I like to keep all of my equipment in as good of shape as possible. In fact, I like to explore getting performance parts to replace worn parts as they die on the car.
Since purchasing the car, I worked the car up to a Malone stage 3 with several upgrades. My complete list of problems since November of 2010 is listed below:
Nothing until 110K when the clutch started shuttering from incorrect mass movement. I changed to a smf clutch, which has been problematic. Totally my fault, so I would recommend staying with the DMF style.
Malone Stage II at 130K due mostly to a packed dpf. Instead of choking up the money for a new dpf, I just deleted the dpf, and the egr while we were at it, while getting a malone stage II. Can't say enough about this upgrade other than running next to the road everyday sucks.
I had an oil pressure sensor go bad at around 175K.
That's it for problems with the car mechanically speaking.
The radio died at around 130K, but I never liked the touch screen anyway, so I replaced it with a nice Alpine with old school knobs and buttons.
Jumping from one slurry hole to another slurry hole in an effort to drain all the holes I can.
No hole to big, no head to high, no fee too excessive!
Slurry Pumper is offline   Reply With Quote
Old January 18th, 2018, 10:03   #6
InfoSec
Fuel Economy: 48-55mpg
Buy my Jetta... It is a blast to drive, and it gets about 48 on the hwy in 6th. Probably about 210hp/370tq... it's old but it only has 150K miles on it. Very reliable/dependable.
The Master of InfoSec - Current '03 Jetta GLS TDI: 02M, Wavetrac LSD, Whitbread downpipe and custom IC piping, Race 520's, VNT1756vk, upgraded SMIC, EGR Delete (obviously), Buzzken 2.5" cat-back w/ turndown, Malone Stage 5 custom, PDlift pump, ARP Head Studs, Phase II: head work, bigger turbo, hotter cam, better pistons/rods, new tires...at least the front ones.
InfoSec is offline   Reply With Quote
Old January 20th, 2018, 11:50   #7
Rodmiser
Fuel Economy: 47 MPG last 10 tanks & 57 MPG BEST
Default Yes 2015 DTI
YES
Avg MPG 45.1 - 2015/2017
322.04 gallons for 12 months diesel fuel -Year 2017
15,138 miles for 12 months on the 2015 jetta tdi s dsg-year 2017
$729.90 total for 12 months for the fuel-year 2017
And service charge of about $700.00 year 2015 to 2017 OK
avg/price for mile 0.049 -2015/2017
diesel LOVE IT
2015 to 2018 40685
Rodmiser is offline   Reply With Quote
Old January 27th, 2018, 11:47   #8
soldierguy
Just struck a deal to trade the Prius in on a ‘15 Jetta TDI S. 12500 miles. More to follow later.
'15 Jetta TDI S DSG
Old January 27th, 2018, 18:39   #9
soldierguy
So Dieter the Diesel is home in the driveway.
It was kind of a no-brainer. The warranty, a car with about 80,000 fewer miles, a SIGNIFICANTLY reduced payment, drives great, quieter than the Prius on the highway (important to me since that's where all my driving is), and even though the fuel & AdBlue expenses will be more than in the Prius, the reduced payment more than makes up for that, even when considering the DSG services every 40K.
I'm happy. I'd toss a pic in here, but I know there's a picture thread elsewhere, and my phone just decided to update, so it's preoccupied.
'15 Jetta TDI S DSG
Old January 27th, 2018, 19:16   #10
rtking
Congrats! I think you chose wisely!
I have a long commute as well (172 miles round trip) and my former 2011 Jetta was absolutely the ticket. Very efficient, quiet, comfortable, and absolutely no issues or repairs (except a cracked DPF, but I kept on driving) and I ran that car to 240K miles before I turned it in for the buy back. In some ways, I wish I had kept it. Not that I don’t like the 328d, but having payments again is no fun.
2011 Jetta TDI w/DSG & Nav: White Gold over Cornsilk leatherette. 240,000+ miles of trouble-free driving. Buy-back completed March 27, 2017
rtking is offline   Reply With Quote
Old January 31st, 2018, 22:04   #11
turbostuff
TDI(s): 2011 Jetta
I commute every week between Houston-Dallas, so roughly 460 miles once a week, plus the driving i do from the crash pad to work. Car has been great, and I have only had to do basic stuff to it. two biggest things I will stress is keep up with your DSG and fuel filter changes, and you will be ok. I have roughly 167k miles on my 2011 now.
turbostuff is offline   Reply With Quote
Old February 1st, 2018, 03:26   #12
soldierguy
I have a long commute as well (172 miles round trip) and my former 2011 Jetta was absolutely the ticket. Very efficient, quiet, comfortable, and absolutely no issues or repairs (except a cracked DPF, but I kept on driving) and I ran that car to 240K miles before I turned it in for the buy back. In some ways, I wish I had kept it. Not that I donít like the 328d, but having payments again is no fun.
Thanks for the feedback. So far I love it. I tend to be easy on vehicles and punctual about maintenance, so I'm hoping the DSG will be just fine.
'15 Jetta TDI S DSG
Old April 18th, 2018, 13:45   #13
16vjohn
I continually break my best tank records, which is interesting... I drive the car harder and faster now than I did when it was new. My average over ~37k miles is 46.0mpg, with my best tank at 52.7 just last week (see sig). I've been on the phase 1 fix for more than a year now. It'll be interesting to see how phase 2 plays out.
16' Fusion Energi // 12' Honda Odyssey
Retired: 15' Jetta TDI 45k // 13' Passat 22k, Buyback // 01' Jetta TDI 177k // 98' Jetta TDI 291k // 00' Jetta TDI 240k // 91' 300D 2.5T // 90' Jetta TD
16vjohn is offline   Reply With Quote
10 Years! 2003 ALH Fuel mileage information and Cost(s) of Ownership hskrdu VW MKIV-A4 TDIs (VE and PD) 56 February 10th, 2016 14:24
At what mileage would you consider a tdi cost of ownership will exceed a tsfi? party_wagon TDI (Diesel) Emissions 14 January 31st, 2016 20:07
High milage cost of ownership? brianbvw VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 33 October 23rd, 2014 20:23
considering a high mileage Jetta wagon--thoughts? jbeall VW MKIV-A4 TDIs (VE and PD) 54 March 5th, 2013 17:20
Diesel Hypochondria: Events of Ownership at High Mileages BrianCT General VW Discussion 20 July 7th, 2006 13:06
Page generated in 0.18395 seconds with 13 queries
[Output: 118.34 Kb. compressed to 99.91 Kb. by saving 18.43 Kb. (15.58%)]
