Old July 6th, 2016, 20:30   #16
young lad
young lad's Avatar
Bought a cluster from this vendor a couple months back, great guy!!! He will try his best to make sure you are happy with item! If you are interested in a full fis this is the guy to buy from!
BUMP!
young lad is offline   Reply With Quote
Old January 2nd, 2018, 21:43   #17
gmenounos
The lack of space in my basement finally exceeded my lack of time so I'm selling clusters again. See http://bitfab.com/tdi for current inventory.
One recent development is that some clever folks have discovered how to patch many of the MKIV clusters to enable needle-sweep. See http://www.users.on.net/~graeme86/sw.../sweep501.html and http://www.users.on.net/~graeme86/sw.../sweep503.html for details. All future clusters that I sell will, if possible, have needle sweep enabled - unless you don't want it.
If I sold you a cluster in the past, I'll be happy to enable needle-sweep (if possible) for free, but you'll have to pay postage both ways or be in the Boston, MA area.
Greg
gmenounos is offline   Reply With Quote
Old January 9th, 2018, 19:32   #18
gmenounos
Just Added: MKIV TDI MFA Sport Cluster - $225
Old January 10th, 2018, 18:17   #19
dirtride
TDI(s): 2003 Golf
Fuel Economy: mid to upper 40's
This is good to hear! Sending you PM.
Mark
03 GOLF ~ GLS ALH EGR (turned it into a mutt)
00 F-350 ~ 7.3 PSD 4WD ZF-6 XLT LBCC (modified, not a mutt)
dirtride is offline   Reply With Quote
Old January 11th, 2018, 20:39   #20
3L3M3NT
3L3M3NT's Avatar
I hope you don't mind me posting this, but there is now a ColorMFA that could be added to the cluster you're getting gmenounos.
https://www.youtube.com/watch?time_c...&v=9AKjIYAWn7g
A little background on it on VWVortex and Facebook.
http://forums.vwvortex.com/showthrea...uster-upgrade!
https://www.facebook.com/permalink.p...38412459827041
Sturgeon Bay, WI Cruise/GTG October 20th, 2018
Fix if you're using Chrome: Chrome fix
Firefox fix
RTDI Build Thread
3L3M3NT is offline   Reply With Quote
Old January 13th, 2018, 09:42   #21
gmenounos
Yes, I know about the ColorMFA, but it takes months to order one and then requires tearing apart the cluster to install. I'm in the process of trying to get one to try out.
http://www.bitfab.com/tdi
Old January 14th, 2018, 20:03   #22
gmenounos
Added another one: MKIV TDI Half-Height Sport Cluster - $225
I will add some full-height ones soon.
Old February 11th, 2018, 21:17   #23
gmenounos
If you bought a FIS cluster and are disappointed that the top 2 lines are blank (because you don't have a VW factory double-DIN radio or navigation system or a 3rd party device such as VFIZ or FIS-Control), there is a relatively inexpensive solution if you know which end of a soldering iron to hold:
https://github.com/ibanezgomez/FISBlocks
I've started building one of these and I can confirm that it actually does write text to the top 2 lines of the display. I still need to finish modifying the OBD cable so I can try it out in the car. Anyway, it looks like a very cool project, it's open source and the parts currently cost less than $25!
Old February 11th, 2018, 21:25   #24
gmenounos
If you have been having trouble getting a 3LB (3-Line BUS) or CAN device to display text/graphics on your FIS cluster, this may help. The first 2 digits of the cluster soft coding needs to be >= 16 when using 3LB and < 16 when using CAN. Then you need to recode the CAN gateway with the same value that it's already set to. This will cause it to rescan the CAN bus, forgetting devices that no longer exist and learning new ones that it finds. It seems that if a cluster was once used with a CAN radio/Navi (say on a workbench or in a different car), it will refuse to recognize data coming over the 3LB until you recode the CAN gateway and make it realize that the radio is no longer there.
See here for more detailed info: http://www.bitfab.com/Help
FS: Full FIS Euro Sport Cluster - 1J5920946CX Jarek Private TDI Items for Sale/Wanted 4 January 14th, 2012 08:43
FS: Full FIS Euro Sport Cluster - 1J5920946C Jarek Private TDI Items for Sale/Wanted 10 July 14th, 2011 14:42
FS: Full FIS Euro Sport Cluster Jarek Private TDI Items for Sale/Wanted 12 February 6th, 2011 15:51
FS: Full FIS Sport Cluster w/ Euro Faces, 3B0920849A vwb5t Private TDI Items for Sale/Wanted 4 January 7th, 2009 05:53
FS: Full FIS Sport Cluster w/ Euro Faces, 3B0920849A soundguybob Private TDI Items for Sale/Wanted 4 October 27th, 2008 14:00
Page generated in 0.20861 seconds with 13 queries
[Output: 95.30 Kb. compressed to 82.21 Kb. by saving 13.09 Kb. (13.74%)]
