tupdegrove
Sold: 2005 (Mk4) VW Jetta TDI 1.9l Philly Area Lower Price $4000
Car Sold
Lowered price...$4000 (Hmm, thought I edited the price in subject)
Pictures (and same ad) at
https://allentown.craigslist.org/cto/6727006587.html
2005 (Mk4) VW Jetta TDI 1.9l Turbo Diesel
- Silver, 4 door sedan, automatic, abs - clean (and no rust)
- 45 MPG
- Leather interior (grey) - clean
- Power windows/locks/mirrors/sunroof, cruise control, keyless entry
- AM/FM Stereo CD & Cassette
- Heated front seats
- Cold A/C, good heat
- Frostheater block/water heater
- Clear headlight lenses
- Trailer hitch
- 191,000 well maintained miles
- VIN: 3VWSR69M45M051610
History:
- 2012 (Jan; 98k miles): Purchased Jetta. Previous owner did timing belt kit (1st time).
- Used can of Diesel Purge once a year direct into injectors.
- Used fuel additive (winter & summer)
- Changed oil & filter every 10k miles. Used 505.01 oil & Mann filters.
- Fuel filter changed every other oil change.
- Have service records & receipts.
- Major engine work done by VW diesel expert (Roman) at Automotive Consulting Services in Hatboro PA.
- 2012 (Jan; 98k miles): Replaced left tie rod.
- 2012 (Mar; 100k miles):Replaced thermostat, thermostat housing, and antifreeze (used G12).
- 2012 (Mar; 100k miles): Replaced right front axle w/raxles.com
- 2014 (Jul; 141k): Flushed & replaced transmission fluid with synthetic.
- 2014 (Aug; ~146k): Trunk lid replaced (had small 2" dent from someone going <15 MPH when I was stopped at light).
- 2015 (Jun; 159k): replaced front & rear driver's side door lock actuators, strut mount, rear control arm bushings, rear brake pad & rotors, replaced brake fluid.
- 2017 (July; 178k): cam checked for wear (no viable wear/damage). New valve cover gasket.
- 2017 (July; 178k): Timing belt kit (2nd time) with water pump, serpentine belt, tensioner, new oem 120 amp alternator, alternator pulley, glow plug harness, all new glow plugs, cleaned EGR valve, CV boot kit, replaced water temp sensor, new intercooler pipe seals, replaced brake booster hose.
- 2017 (Aug; 182k): oem turbocharger w/install kit, intercooler pipe seal, egr cooler, new oil feed line, upper intake boot, replaced right rear door lock actuator.
- 2018 (Feb; 186k) Replaced rear struts & mounts.
Known issues:
- Audio amp in trunk consumes power when car is off. Not a problem if car is used every few days. Pulled radio fuse. Connect to use radio.
Extras:
- Bentley 1999-2005 Service Manual for Jetta, Golf, and GTI
- Have lots of spare bulbs for all lights (headlights, running lights, backup lights, tail lights, brake lights, license plate, etc)
- Set of disc brake pads
- G2 Antifreeze
- Fuel additive (I think the winter one).
Runs and drives very smooth.
Price lowered to $4000 (cash). Clean title in hand.
Text or call Tim at 610-298-5829
Car Sold
- 45 MPG
- Trailer hitch
History:
Known issues:
Extras:
- G2 Antifreeze
