Tyrel
hello all, right now i am experiencing intermittent hard brakes and same with turbo. Have read threads that describe the plastic hose from the vacuum pump which i have changed, noticed when removing this plastic pipe the was suction noise when i removed it. took car for drive and thought i had the issue beat, but about 5-7 minutes down the road, same issue again. i had noticed that the aluminum tube coming out of the vacuum pump can turn and is abit wobbly, not sure if it is supposed to be like that or not. When i placed my finger over the end i felt the vacuum present. after returning home i placed a hose from the check valve at the vacuum pump out to a vacuum gauge and it didn't register anything. When i had the check valve out i could blow into one end and nothing come out but blowing on the other end allowed air to pass through so it is working. Since the gauge didn't register anything i am suspecting a intermittent vacuum pump problem not sure if this is even possible.
Any help would be appreciated.
