tdi_lamb
Greetings,
I've experienced some trouble & grinding going from 3rd to 4th a few times in the last couple of weeks during hard aceleration. It would only occur when I rev beyond 3K rpm (3500 - 4K rpm) Had the same problem happen on the way home today, but now car is now stuck in 3rd gear right now and I can't get it out
. Car runs as it should in 3rd gear -- clutch seems fine, you just can't shift. It grinds like a SOB if you try and pull it out with the car running.
Does anybody have any experience with this problem? Does this sound like a partial transmission failure? Or maybe just a linkage problem?
Grinding can't be good.
Car's a stock 99 A3 TDI with 340K KM on the clock.
