couttsdesign
I'm working on a project which requires the relocation of the oil filter housing/cooler (ALH engine). So, I'd like to open a discussion to better understand the oil filter housing function and problems that I will have to address in the relocation.
One issue I am not clear about is the oil cooler/heater. I understand on a basic level that the oil is first heated via circulating coolant and then once warm the oil is then cooled by the same circulating coolant. I live in southern California where the temperature is moderate/warm for most of the year. How does this affect the oil cooler/heater function? Wouldn't warming the oil quickly from start up only matter for cold climates?? Once warmed up, how important is it to cool the oil? Basically, can I eliminate the oil cooler/heater all together?
Regarding the oil filtering, I've taken off and examined the filter housing and there appears to be a pressure valve at the port where oil enters the housing. What is the purpose of this one way valve? I assume it ensures the housing is always full of oil so on start up there will not be a delay in building oil pressure??
I'm asking these questions because ideally I'd like to use a oil filter relocation kit. The plan is to make a block off plate where the filter housing bolts to the block, tap it for supply/return ports and run hoses to a new oil filter location. After the oil is filtered i could run a flexible turbo supply line.
I am considering an Amsoil bypass kit...
http://www.amsoil.com/storefront/bf.aspx
Any thoughts, criticisms, warnings would be greatly appreciated. We all know how important oil is to our diesel motors, so I really need to trouble shoot this issue.
