burn_your_money
Every now and again my 05 will run very rough, almost like it's missing. I was out checking my torsion value today and the car started acting up. I scanned through the different channels and found channel 3 to be of interest. Here is a screen shot of the graph
I then took a log and brought the RPMs up incrementally until things seemed to smooth out. I'm not sure how to upload that so it makes sense but the car smoothed out around 1600 RPM and then when I brought it back to idle it was running smooth again.
These are the 3 codes I get regularly:
17057 - Cylinder 3 Glow Plug Circuit (Q12)
16485 - Mass Air Flow Sensor (G70)
16683 - Boost Pressure Regulation
I've only owned the car 3000 kms (2500 miles) and it didn't come with any maintenance history. So far I've replaced the intercooler hose right off the turbo and the one right before the "throttle body" plus all my fluids and filters. Car has 460k kms (285k mi).
I haven't had time to do a lot of other things on this car yet.
It's averaging 6.9l/100 (34.3 USMPG) which I think is bad (but it's a lot better than the van it replaced)
I'm not sure where to go from here so I would appreciate some input.
