megha_jones
ok i bought i 2001 jetta tdi about 6 months ago. i new the injector pump was going bad because it was making the tell tell noise. i told the guy selling it, he said thats what the dealer said but the mechanic who did his timing belt said that didnt make any since the pump was in the tank. (i should have ran)
I put a stethoscope on the valve cover and the pump and it was definitly the pump. 2 weeks ago im going down the road and i get a sound like a bunch of marbles going threw the motor(might be an exageration). the noise stopes then it drives a mile then and dies.
i order a pump and a belt kit since i cant trust his mechanic. the old water pump was not changed or any of the small rollers(one was bad). and the new tensioner he used was crack and the spring was coming out the side.
also the cam is cracked were he torqued it using the cam holding plate.
now the problem. i put it all together and it runs great. (thanks to the great how to on doing the timing belt here). the problem is that i have noise like a bad lifter. i put my handy stethoscope on it and the pump makes noise but is acceptable. i couldt get the cam exact because of the slack in the bracket. could the cam being off cause the car to "diesel". this is what the car sound like but i know they are not to be loud for a diesel.
is it also possible that when the pump when and the belt was under tensioned that the timing belt sliped and ive got some valve damage(would it run so good). or do you have a better idea.
thanks for any suggestion.
ps i will spell check this tonight when im on a computer with spell check. lol
